need help with timing on d16a6
Old Aug 29, 2006 | 12:20 PM
charlie_sohc's Avatar
Default need help with timing on d16a6
....repost from technical form.....Ok guys i haven't touch my timing in years....now i need some pointers. ... ok on the ef9 d16a6 is the timing gun is set to zero..when you shoot it with the timing gun..it should be on the red mark in the middle right?? .and when you advance the timing gun to 16 +/- 2 degree....it will be on the white line(TDC)....give some feed back guys...
Old Aug 29, 2006 | 12:28 PM
jlicrx's Avatar
Default Re: need help with timing on d16a6 (charlie_sohc)
you are correct
Old Aug 29, 2006 | 01:18 PM
thesmogman's Avatar
You got it! I thought I was going to have to explain it again.
Old Aug 29, 2006 | 02:13 PM
Default Re: need help with timing on d16a6 (thesmogman)
thanks guys...i just want to make sure..
Ilovemyef9
Oct 21, 2010 04:41 PM
fe519
Nov 10, 2003 08:32 PM
