helicoil for plug?
Old Aug 29, 2006 | 11:08 AM
slowcrxsib16's Avatar
Default helicoil for plug?
hey guys, new to this bike stuff, my friend is selling an 02 cbr600 and he said that it needs a helicoil for the plug, or something. said that honda would do it for around 200 bucks. the guy wants 3500 for it, not sure on the miles, im gonna find that out tonight. what do yall think about the helicoil thing?? im not sure
Old Aug 29, 2006 | 11:16 AM
MSchu's Avatar
My Name is Nobody
Default Re: helicoil for plug? (slowcrxsib16)
whats wrong with helicoil?
Old Aug 29, 2006 | 11:41 AM
Default Re: helicoil for plug? (MSchu)
the guy said that the plug was crossthreaded or something like that, it runs fine but said that it should be fixed
Old Aug 29, 2006 | 11:43 AM
MSchu's Avatar
My Name is Nobody
absolutley should be fixed... plugs often get heated so high that they become fused with the soft aluminum, and pull out threads(they are not really cross threaded) this is why I try and use thread lube(graphite). but if the inevitable happens helicoil is what is needed to fix it
Old Aug 29, 2006 | 11:54 AM
if the helicoil has to be replaced, what does that run usually?? im not gonna do it, how much would a dealer usually charge?
Old Aug 29, 2006 | 12:02 PM
MSchu's Avatar
My Name is Nobody
head off I have to say around $75-125... I'd just do it myself, but if your more inclined to use a service, use a machine shop NOT the dealer.
Old Aug 29, 2006 | 12:26 PM
is there any way to do it with the head on?? i mean, i dont know what it consists. im assuming i have to take the farrings off and what not right?? is it just a normal helicoil?? like for a stripped out bolt?? the little spring thing? how long should it hold up?? like i said, im a noob to this bike thing
Old Aug 29, 2006 | 12:29 PM
MSchu's Avatar
My Name is Nobody
I thnk I have heard of folks doing thread replacement with the head on, but I wouldn't... call a local machine shop and get there advice for your problem.
http://fulltorque.com/sparkplug.htm
Modified by MSchu at 1:40 PM 8/29/2006
Old Aug 29, 2006 | 12:59 PM
D Day's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">use a machine shop NOT the dealer.</TD></TR></TABLE>
QFT.
machine shops are soo much better and machining these parts and making sure the area they drill in the least intrusive possible. i would also have to say that for the most part you will need to remove the head. you dont want any scrappy scraps falling in and then getting stuck or damaging the cylinders.
salaamq
Dec 28, 2011 09:59 PM
NOTDISFA5
Jun 27, 2010 12:02 PM
holmesnmanny
Jun 20, 2010 02:52 AM
SurferDude905
Jun 8, 2009 07:23 PM
CeoStatus0
Sep 26, 2007 05:33 PM
