gsr cams and cam gears...
Old Aug 29, 2006 | 03:41 AM
RoB316's Avatar
Default gsr cams and cam gears...
i have my motor all ripped apart and i took the cams out with the cam gears still attached. my problem is that i cannot get the bolt the bolts down the cam gear out. ive tried everything, vice grips, air ratchet, air gun and im all out of ideas. if any of you guys have one, id like to hear it thanks!
Old Aug 29, 2006 | 03:46 AM
Amped's Avatar
Default Re: gsr cams and cam gears... (RoB316)
If you use a decent air gun it should take them right off. Make sure when doing this you have a good bit on the bolt head. Slipping off could make some problems for yourself. I would then take it to a engine builder or a good shop that has friendly people and ask there advice, they could help you out. Just put the cam gear in a vice or have a friend hold the cam with a rag. The best way i found is a healthy air gun,a 1/2 inch
Old Aug 29, 2006 | 05:25 AM
Lewie's Avatar
I'm here for the gangbang!
Make sure you don't ruin the cam or strip the cam gears (teeth) w/ a vice
Old Aug 29, 2006 | 07:16 AM
RoB316's Avatar
Default Re: (Lewie)
ok i put a towel over the cam and then put it in the vice
Old Aug 29, 2006 | 07:27 AM
dmacaalay's Avatar
Default Re: (RoB316)
no, itll be easier to just put the cam gear in a vice..
Old Aug 29, 2006 | 08:39 AM
D-meet07's Avatar
Default Re: (dmacaalay)
I used a impact gun. Put a towel around the cam and held it tight. I guess I have a monkey grip or something. That worked for me.
Old Aug 29, 2006 | 08:43 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (D-meet07)
If you can't get it off I would recommend taking it to a mechanic shop and asking them to take it off for you. I have done that several times with different parts and have never been charged. Even if they do charge you, they probably won't charge more than $5 and to me it is worth $5 vs replacing a part this is more expensive.
Old Aug 29, 2006 | 06:37 PM
RoB316's Avatar
Default Re: (SlammedDC2)
thanks guys i ended up getting them off with a 1/2'' air impact gun. now my manual says that there is only 27 lbs-ft of torque needed on them. does that sound like enough??
Old Aug 29, 2006 | 06:47 PM
lVlemphizStylez's Avatar
umm check the manual again its more like 41 ft/lbs
Old Aug 29, 2006 | 07:25 PM
B2FiNiTY's Avatar
Default Re: (lVlemphizStylez)
It should be very easy to remove. Have a friend hold it while you use the impact to take it off.
kpjo4
Jul 11, 2009 06:44 AM
TB123
Mar 24, 2008 01:36 PM
IIVIIoOkY
Feb 4, 2006 10:19 PM
A train
Mar 15, 2005 06:35 PM
fastludeh22
Nov 20, 2002 07:38 PM
