Suspension & Brakes Theory, alignment, spring rates....
Testing for quaife gear in manual rack
Old Aug 29, 2006 | 03:28 AM
Eyal 951's Avatar
Default Testing for quaife gear in manual rack
I pulled my stock rack off for this rebuilt with shortened ratio gear, and teste both off the car. I counted the amount of turns the part that bolts into the U joint on the steering column it takes to go from lock to lock. Both were exactly the same... 4 turns. Did I get ripped off, or is this not a proper way to test?
Old Aug 29, 2006 | 09:26 AM
Tyson's Avatar
Default Re: Testing for quaife gear in manual rack (Eyal 951)
it should be different.
Old Aug 29, 2006 | 10:00 AM
Eyal 951's Avatar
Default Re: Testing for quaife gear in manual rack (Tyson)
thanks. the guy I bought it from insists that its shortened ratio. I bought a GSR rack that I will loop I geuss, unless I can somehow find out if its indeed shortened.
Old Aug 29, 2006 | 10:03 AM
Tyson's Avatar
why arent you counting gears?
and you are swapping pinions along with the rack too right?
Old Aug 29, 2006 | 10:50 AM
Eyal 951's Avatar
the rack is assembled, I just bought an assembled rack from the guy. So I was planning to just throw it in.
What do you mean by counting gears? That requires disassembly right?
Old Aug 29, 2006 | 10:52 AM
Tyson's Avatar
yeah, i figured it was disassembled.
if the rotations are the same, then its the same rack. plain and simple.
Old Aug 29, 2006 | 10:54 AM
Eyal 951's Avatar
thats exactly what I thought. The guy insists its not. Sucks. I geuss I'll run the Integra rack. Its actually shorten then quaife anyway right?
Old Aug 29, 2006 | 10:56 AM
Tyson's Avatar
i dont know what the ratios are for anything other than EF's.
Old Aug 30, 2006 | 01:31 PM
Stinkycheezmonky's Avatar
Suspetise...
Integra rack = Quaife manual rack.
hcaulfield57
26
Jun 12, 2017 08:08 PM
Steeve_Civic
Dec 28, 2013 11:00 AM
Sl0w_S4
Nov 17, 2013 03:28 PM
10cjennings
14
Aug 17, 2013 08:50 PM
