Idle Air Control valve question!i!i!i!i!
Old Aug 29, 2006 | 12:03 AM
jdmcrx_echelon's Avatar
Default Idle Air Control valve question!i!i!i!i!
Just swapped a B18A1 into the rex.Come to find out there was no idle air control valve connector on the harness.so i by passed(looped or hooked together) the two vacuum hoses running into it.Car runs fine.SHould i try wiring it up or is it not a problem since it runs fine?
Old Aug 29, 2006 | 12:33 AM
NikoZai's Avatar
Default Re: Idle Air Control valve question!i!i!i!i! (jdmcrx_echelon)
But there IS a IACV Plug on your engine harness...
It's has a blue/black wire - look around.
ShatiaNichols
Jan 31, 2012 08:15 PM
cbabyby
Apr 22, 2005 07:46 AM
geldingmakr
Aug 4, 2004 09:11 AM
