would a throttle body from a second gen integra fit third gen integra?
I dont think the map sensor is on the gen2 integra trottle bodys. So i dont think it will work on a gen3 where the map is on the tb.
it will bolt on. but as was said before, you will have to change out the TPS
and run a vacuum line to the map sensor
thanks for the reply guys. i tried it this weekend and as i was told, it does bolt on but the coolant inlet faces a different direction and there are two of them instead of one like the TB of the third gen.
Keith P
Mar 11, 2005 01:59 PM
