HELP!?!?!?!?
Old Aug 28, 2006 | 01:54 PM
JJ's civic's Avatar
Default HELP!?!?!?!? wheel bearing??
went to go to work today. and i heard sumthing that sounded like something was draging. after work i went out and fixed y exhaust from haning near the resanotor. took for a drive and there's still a noise near the driver side back tire. just wondering what it could be. my thought is a wheel bearing?
help please i think that needs to be fixed lol
Modified by joeny12985 at 6:08 PM 8/28/2006
Old Aug 28, 2006 | 02:57 PM
JJ's civic's Avatar
Default Re: HELP!?!?!?!? wheel bearing?? (joeny12985)
anyone know please
Old Aug 28, 2006 | 03:06 PM
C_R_X_V_T_E_C's Avatar
what kinda noise is it? is it a dragging, or a grinding or a humming?
Old Aug 28, 2006 | 04:02 PM
JJ's civic's Avatar
Default Re: HELP!?!?!?!? wheel bearing?? (C_R_X_V_T_E_C)
i thought it was a draging noise my gf says kinda of like a "lighty scraping noise"
Old Aug 29, 2006 | 02:49 AM
JJ's civic's Avatar
bump for help please
Old Aug 29, 2006 | 12:04 PM
JJ's civic's Avatar
anyone???
Old Aug 29, 2006 | 01:08 PM
1 Fly SI's Avatar
could be brakes,do you have disk or drum? My rear mud flap use to drag the ground on my old crx.
Old Aug 29, 2006 | 01:11 PM
JJ's civic's Avatar
Default Re: HELP!?!?!?!? wheel bearing?? (1 Fly SI)
nothing is dragging i had my gf look as i drove up and down the driveway. and she's bnot car stupid
Old Aug 29, 2006 | 03:39 PM
thesmogman's Avatar
Does the sound increase with speed. A wheel bearing will make a whirling noise that increases with speed.
I would jack up each side and give the wheel a turn and see if it makes the noise, also grab the wheel and try to move it in and out to see if you have any play in the bearing.
Also when the front brakes wear down there is a little metal scraper that makes alot of noise. It is kind of a warning system.
Here's a couple to check out!
Old Aug 29, 2006 | 05:33 PM
JJ's civic's Avatar
Default Re: HELP!?!?!?!? wheel bearing?? (thesmogman)
that's all well and good but it's my back that's making noise
Old Aug 29, 2006 | 05:58 PM
eda6's Avatar
when i suspect i bearing, i always isolate the hub by removing the caliper. compare it to the passenger side. if you feel more resisatnce or if it sounds bad then it's a bad bearing. do you see grease/dirt on the cover?
Old Aug 30, 2006 | 02:31 AM
JJ's civic's Avatar
Default Re: HELP!?!?!?!? wheel bearing?? (eda6)
it's my rear hub and i'm trying to take the one off my parts car first before i break anything on my dd. i need it to go to work and back
Old Aug 30, 2006 | 03:46 AM
ludesrv's Avatar
Open up your rear drums and inspect them. You could of done what happened to me. You busted a springs on the inside and the rear drum fell apart on the inside. Scratches the **** out of it. Wheel bearings grind when they seize up good. Check the tires from rubbing or anything else interferring with rotating assemblies such as wheels.
Old Aug 30, 2006 | 12:46 PM
JJ's civic's Avatar
Default Re: (ludesrv)
well the noise stoped so i'm jsut going to listen for it again
Red-Rag-B18
May 7, 2010 09:16 AM
dohc_profile
Sep 4, 2007 11:54 AM
Linh.
20
Nov 18, 2005 11:49 PM
TEG98
Jun 20, 2005 01:54 PM
