Relocating Battery to trunk.
Old Aug 28, 2006 | 11:06 AM
ctownintegra's Avatar
Default Relocating Battery to trunk.
What gauge wire is good enough? 2 or 0?
I should run that under the carpet, through the firewall and to a Distribution block?
I am also making me a new Alternator wire since mine is corroded to hell and back.
I have already re-done my headlight harnesses.
Possible places to hide the distribution block?
Just decided I wanted to do this while I wait on my windshield to get replaced.
Old Aug 28, 2006 | 01:57 PM
ITRnorway's Avatar
what box do you use for the battery?
Old Aug 28, 2006 | 05:15 PM
I can get a plastic battery box from work.
Old Aug 29, 2006 | 10:14 AM
rtype11's Avatar
Default Re: Relocating Battery to trunk. (ctownintegra)
you can save some money and use 1 gauge welding cable. only problem is that it only comes in black.
Old Aug 29, 2006 | 10:23 AM
xiaogou's Avatar
You can buy red battery cable from http://www.wiringproducts.com (red or black).
I recommend 1 or 0 gauge.
Run the cable under the carpet and through the back of the hole behind the fuse box. You can put the distribution block under your air intake or battery tray.
Also, get the fuseable distribution block. I got mine from cardomain.com (rockford fosgate). Got one 150 amp fuse going to the fuse box and one 100 amp fuse going to the starter. In the trunk I have a 150 amp fuse on the + battery cable.
Good luck!
Old Aug 29, 2006 | 11:39 AM
Pics?
Old Aug 29, 2006 | 03:40 PM
Enzo Speed's Avatar
Default Re: (ctownintegra)
Why move the battery to the trunk? Maybe it's a noobish question, but I thought most people moved the battery to the front bumper in a FWD car.
Old Aug 30, 2006 | 05:25 PM
xiaogou's Avatar
Better weight distribution. Hondas are front heavy as is. A lot of people give the "more weight for more traction." While they are correct to a degree, a traction bar would be the best option.
Old Aug 31, 2006 | 05:59 AM
Also, cleans up engine bay signifigantly. So much easier to hook up audio equipment. Less wire mess.
I should be starting on this tomorrow or the next day.
Going to buy some wire from the sound shop from here. Kicker makes an awesome super flexable 0/1 gauge wire.
I have terminals that accept 2 4 gauge and 4 8 gauge wires though. So I need to find a way to get the 0/1 wire hooked up.
I should def. be doing the alernator wire though.
cubnsensation
22
Feb 23, 2018 09:11 AM
JuneBugDrfter
Feb 26, 2013 11:49 AM
4DRmafia
21
Jan 13, 2009 07:11 AM
mini-cRx
Oct 3, 2002 09:38 AM
