Help fidanza flywheel question
Old Aug 28, 2006 | 08:53 AM
jspecda6's Avatar
Default Help fidanza flywheel question
Is it true that when you install a fidanza 7.5lbs flywheel that you will lose torque?
Old Aug 28, 2006 | 08:57 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: Help fidanza flywheel question (jspecda6)
I dont think so, I have read, that a lighter flywheel will suck with normal driveability. Meaning if your stuck in traffic it is harder to drive because you lose inertia from the motor.
Old Aug 28, 2006 | 08:58 AM
jspecda6's Avatar
Default Re: Help fidanza flywheel question (Kiniku Chunks!!!)
it would make sense that when installing it, and rpm is reached quicker that more power and torque would be sent to the wheels am i right or wrong?
Old Aug 28, 2006 | 09:47 AM
lVlemphizStylez's Avatar
the flywheel has its best function out of gear (IE rev matching...shifting...etc) There are studies that show it increases torque in the LOWER gears, but not drastically..But it certainly does not lose torque
Old Aug 28, 2006 | 10:54 AM
Sam92Teg's Avatar
Default Re: Help fidanza flywheel question (lVlemphizStylez)
I am using a Fidanza 7.5 on my B18A and have zero driveability issues, in traffic, on hills, or any other condition. I guess it is more a matter of driving skill, but anyone should be able to master it. Same goes for puck clutches.
92B20VTEC
Jul 18, 2009 09:26 AM
Tyte-S
Oct 31, 2007 07:34 AM
djsin
Mar 31, 2005 05:15 PM
redmethods
May 25, 2004 04:39 PM
mattL
Apr 19, 2002 05:40 PM
