I go through throwout bearings MUCH too often
Old Aug 28, 2006 | 08:01 AM
mgags7's Avatar
Default I go through throwout bearings MUCH too often
Anyone else here familiar with the bad throwout bearing noise, basically its like i high pitched cricket, and it chirps whenever your foot is off the clutch.
When i put the motor in my car 2 years ago, i used the throwout bearing that clutchmasters sent me, it shitted out within the year, and i deduced that aftermarket throwout bearings are shitty, if you look, theyre made of freakin plastic.....
SO, i swap it out for an oem honda one, yes it was used, but only for like 30k, and not even 6 months later, the sound is back.
Anyone have ideas, the transmission was changed when i changed the first bearing out, so thats not the problem, and my clutch isn't riding it or anything, so thats not it, anyone know why i'm frying these things??
thanks fellas
Old Aug 28, 2006 | 08:08 AM
nonvteclude's Avatar
Default Re: I go through throwout bearings MUCH too often (mgags7)
do you power shift alot? if you take the car to high rpm and power shift often that would be a factor
Old Aug 28, 2006 | 08:12 AM
98TypeSH's Avatar
Default Re: I go through throwout bearings MUCH too often (nonvteclude)
When i put my ACT clutch in the T/O bearing went rather quickly.
When im engaging into first from a stop and just starting to roll, sometimes ill get an INSANE horse sound ( really really loud whine/creak ) and also every gear i hit while moving is followed by a nice high pitched quick cricket type noise. Im way to lazy/busy to pull my tranny. Especially in my SH.
Old Aug 28, 2006 | 08:22 AM
Shakes's Avatar
space cadet
Default Re: I go through throwout bearings MUCH too often (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">When i put my ACT clutch in the T/O bearing went rather quickly.
When im engaging into first from a stop and just starting to roll, sometimes ill get an INSANE horse sound ( really really loud whine/creak ) and also every gear i hit while moving is followed by a nice high pitched quick cricket type noise. Im way to lazy/busy to pull my tranny. Especially in my SH. </TD></TR></TABLE>
James yours is horribly loud. I never had an issue with either of mine.
Old Aug 28, 2006 | 09:06 AM
hella_usdm's Avatar
I'm going to install an act clutch this weekend due to the tob giving way. Should I ditch the act tob in favor of an oem one???
Old Aug 28, 2006 | 10:31 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude &raquo;</TD></TR><TR><TD CLASS="quote">do you power shift alot? if you take the car to high rpm and power shift often that would be a factor</TD></TR></TABLE>
nah i dont powershift man, you cant really do that to honda transmissions and expect the syncros to last at all
the fact that your car does it as youre starting to roll makes me thing the actual bearing part of yours is bad
the wiggle noise i get is only when the clutch is fully out, aka when the bearing is riding the collar on the input shaft housing on the trans
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hella_usdm &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to install an act clutch this weekend due to the tob giving way. Should I ditch the act tob in favor of an oem one???</TD></TR></TABLE>
i would say definitely use an oem one, pulling the trans sucks....
Old Aug 28, 2006 | 10:51 AM
98vtec's Avatar
moderator emeritus
honestly james, yours doesnt sound like a throw out bearing problem to me. Maybe more of a problem with the clutch or pressure plate being dirty and not grabbing well initially?.?.?
matt, the only t/o bearing problem i ever had was with ACT. I got maybe 10k miles out of it. I also had that engagement squeal after about 1k miles on the clutch.
I had a dynapac clutch before this action and i had maybe 10k miles on it and when i pulled everything out, the t/o had very little play in it and still spun freely. Hell my clutch looked almost brand new with the amount of pad left on it.
so far the only problem i have with this action clutch is the engagement point, which hopefully will be fixed after changing the clutch fluid.
Old Aug 28, 2006 | 10:59 AM
skunked's Avatar
Default Re: I go through throwout bearings MUCH too often (98vtec)
are you sure it had "30K" miles on it?
Something like that I would only use a new OE part to avoid a days work to potentially only save a few bucks in the long run.
Old Aug 28, 2006 | 11:07 AM
mgags7's Avatar
yea it was a stupid mistake, we had two throwout bearings sitting there a new one and an old one, the new one got thrown away accidentally (not by me) and then i had to have my car done in time for work so i threw it in, pissed me off, but i had to at the time, i figured it would be ok, it came off of my brother's car
Old Aug 28, 2006 | 11:12 AM
skunked's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">yea it was a stupid mistake, we had two throwout bearings sitting there a new one and an old one, the new one got thrown away accidentally (not by me) and then i had to have my car done in time for work so i threw it in, pissed me off, but i had to at the time, i figured it would be ok, it came off of my brother's car</TD></TR></TABLE>
If it sat around, got wet or something it could have effected the life of the bearing. If you sit at the light with your foot on the clutch pedal allot it can also kill the bearing faster.
Old Aug 28, 2006 | 04:49 PM
prelude_h22vtec's Avatar
god mine's been doing that freaking cricket crap for like a month. but there's no way i feel like pulling the tranny unless i'm at least going to replace the clutch too.
Old Aug 29, 2006 | 06:32 PM
SteveoBA8's Avatar
Default Re: (prelude_h22vtec)
During spring break i did my rearmain./fly/clutch/brand new oem honda tob. greased it.
***** only makes the "crickett" sound when it's humid/rains outside really annoying.
Old Aug 29, 2006 | 06:40 PM
classified's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
If you sit at the light with your foot on the clutch pedal allot it can also kill the bearing faster. </TD></TR></TABLE>
What else can you do haha throw it in neutral all the time?
Old Aug 29, 2006 | 07:20 PM
well yeah.
Old Aug 29, 2006 | 07:24 PM
roller3804's Avatar
when ur at a stop do u keep the clutch in or put in neutral and let the clutch out?
Old Aug 29, 2006 | 08:54 PM
mgags7's Avatar
i always put it into neutral
Old Aug 29, 2006 | 10:19 PM
98TypeSH's Avatar
i too always put it in neutral.
I agree with you doug. My car sounds like its going to ****** explode. I really, really , really dont want to pull the trans without a lift while just on jackstands. It really just doesnt sound like a good time to me. When the clutch actually starts to take a ****, ill have it all done at once. Until then, its all about the horse.
Old Aug 29, 2006 | 10:33 PM
mgags7's Avatar
haha yeah i will deal with it too, it takes me about 4-5 hours to get that thing in and out now, and thats after doing it like 4 times......
Old Aug 29, 2006 | 10:47 PM
soundbomber's Avatar
haha i wouldn't want to do it if it ain't necessary do. it's a pain in the *** anyway you look at it
Old Aug 30, 2006 | 06:01 AM
integra15's Avatar
Default Re: (soundbomber)
Did you use the urea grease?
I am soon going to replace mine because of the cricket noise, and hope the new oem bearing and a lot of grease will solve the problem.
Old Aug 30, 2006 | 06:10 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">haha i wouldn't want to do it if it ain't necessary do. it's a pain in the *** anyway you look at it</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">"it's ******* leeooopard, homes!"</TD></TR></TABLE>
lol man good stuff
Old Aug 30, 2006 | 09:47 AM
hella_usdm's Avatar
so the oem one isn't any better than an ACT ones that come with their clutches? I read that theirs are better than oem. What should I do when I put the new clutch in then?
Old Aug 30, 2006 | 10:15 AM
98TypeSH's Avatar
Default Re: (hella_usdm)
Use a brand new OEM honda throwout bearing and make sure it is lubed up real good.
Old Aug 30, 2006 | 10:28 AM
Shakes's Avatar
space cadet
Default Re: (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">Use a brand new OEM honda throwout bearing and make sure it is lubed up real good.</TD></TR></TABLE>
Lubed up? Seriously I took mine out of the honda bag and put it on. It should come from the factory internally lubed etc. Shouldn't it?
Old Aug 30, 2006 | 10:52 AM
98vtec's Avatar
moderator emeritus
Default Re: (Shakes)
the only parts i ever greased where the main shaft and shift fork. I never physically put any on the T/O although im sure it got greased upon install on the mainshaft.
