B16a1 bogs at 6 grand
Old Aug 28, 2006 | 07:04 AM
blub16hatch's Avatar
Default B16a1 bogs at 6 grand
i have 91 hatch with a b16a1, when i get on vtec it bogs at 6000, do any one have any iddeas what could be causing this.
Old Aug 28, 2006 | 08:07 AM
90b20vteckidd's Avatar
Default Re: B16a1 bogs at 6 grand (blub16hatch)
could be fuel filter. also, i once saw this on a customers car. he attempted to install cams himself and tightened the valves too tight. well he flatspotted the cams and when he would get to about 5.5k it would bogg and not go anywhere, as if the car was on a rev limiter.
my advice, check your fuel. and timing.
Old Aug 28, 2006 | 09:21 AM
salman's Avatar
MOstly its Fuel, check the fuel system
Old Aug 28, 2006 | 09:22 AM
salman's Avatar
LOw fuel, ur fuel pump or fuel filter is weak.
Old Aug 28, 2006 | 10:11 AM
crx_88_si's Avatar
are you sure vtec is actually engaging? might not be!
Old Aug 28, 2006 | 10:53 AM
i am sure that the vtec is engaging because i have vacf and it is set at 5200 i hear it and feel it but then its like i hit a invisible rev limiter
Old Aug 28, 2006 | 11:08 AM
Craigp23usa's Avatar
do you have the stock fpr? probobally the fuel pump though.
Old Aug 28, 2006 | 12:21 PM
SiNgLeCaMmOnStA's Avatar
Default Re: B16a1 bogs at 6 grand (Craigp23usa)
It coul be the distributor my homies rex bogged at 2,500 k and it was his distributor.
bongsky
Sep 25, 2017 07:27 PM
sasinorm01
Mar 19, 2015 09:28 AM
Em1Rookie
Sep 30, 2006 02:16 PM
crnimacak
Apr 21, 2006 10:11 PM
