is it safe if i move my battery back?
Old Aug 28, 2006 | 03:46 AM
arabian129's Avatar
Default is it safe if i move my battery back?
i have a crx with ZC. I want to do some mods,and i dont have much space in front or under my hood. So is it safe if i place it back with long wires?
Old Aug 28, 2006 | 03:55 AM
Boosted Chemist's Avatar
Default Re: is it safe if i move my battery back? (arabian129)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arabian129 &raquo;</TD></TR><TR><TD CLASS="quote">i have a crx with ZC. I want to do some mods,and i dont have much space in front or under my hood. So is it safe if i place it back with long wires?</TD></TR></TABLE>
yes just use an inline fuse and large battery cables
Old Aug 28, 2006 | 05:50 AM
purplecrx's Avatar
And a battery box.
Old Aug 28, 2006 | 06:12 AM
ludesrv's Avatar
Default Re: (purplecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplecrx &raquo;</TD></TR><TR><TD CLASS="quote">And a battery box.</TD></TR></TABLE>
And a drycell battery. The gases released by conventional batteries is toxic, and shouldn't be trapped in your car, with or without the box. I have a optima red-top in my hatch, sitting where the spare should be, full sized spare mounted next to it .
Old Aug 28, 2006 | 06:26 AM
xplicit ef's Avatar
post a DIY when u do, id like to do this myself
Old Aug 28, 2006 | 06:33 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
And a drycell battery.</TD></TR></TABLE>
Definately get a dry cell.
Old Aug 28, 2006 | 07:19 AM
91bluehatch's Avatar
Default Re: (NAallTheWAY)
I'm running a optima redtop in the rear with a open battery tray and havent had any problems since its install a year ago
Old Aug 28, 2006 | 07:25 AM
Suck my DX's Avatar
Default Re: (91bluehatch)
what do you need to do to pass tech inspection with a cabin mounted battery?
would a simple tie down be sufficient?
Old Aug 28, 2006 | 07:42 AM
Loserkidwac's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">what do you need to do to pass tech inspection with a cabin mounted battery?
would a simple tie down be sufficient?</TD></TR></TABLE>
I believe it has to be in an approved battery box and you also need a kill switch mounted outside the car
Old Aug 28, 2006 | 07:44 AM
ludesrv's Avatar
Default Re: (Loserkidwac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">
I believe it has to be in an approved battery box and you also need a kill switch mounted outside the car</TD></TR></TABLE>
You would need an approved box for sure. The kill switch is MANDATORY regardless of where the battery is located to pass tech-inspection for racing. The hatch lock hole is the perfect hole to put it in.
Old Aug 28, 2006 | 08:43 AM
Suck my DX's Avatar
GOOD LOOKIN ON THE INFO
Old Aug 28, 2006 | 08:45 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">GOOD LOOKIN ON THE INFO </TD></TR></TABLE>
The battery kill switch is only mandatory in autocross racing (non open to public events) and 13.5 second cars or faster for 1/4 mile racing I beleive.
Old Aug 28, 2006 | 09:13 AM
The battery kill switch is only mandatory in autocross racing (non open to public events) and 13.5 second cars or faster for 1/4 mile racing I beleive.</TD></TR></TABLE>
Looks like i might need to look into one then since my turbo setup should put me well past that mark, hopefully
Old Aug 28, 2006 | 09:17 AM
ludesrv's Avatar
Looks like i might need to look into one then since my turbo setup should put me well past that mark, hopefully </TD></TR></TABLE>
That rule applies to non-public events. Going to a test and tune on a general friday night, you won't need one.
Besides, only put one in if you break that mark, don't butcher the look of a car (they are ugly).
Old Aug 28, 2006 | 09:20 AM
Ah, cool, i didn't really want to add one if i didn't have to, and yea i probably will only run it a public events
Old Aug 28, 2006 | 09:54 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac &raquo;</TD></TR><TR><TD CLASS="quote">Ah, cool, i didn't really want to add one if i didn't have to, and yea i probably will only run it a public events</TD></TR></TABLE>
Once you hit 13.999 you need a helmet to race.
Old Aug 28, 2006 | 11:45 AM
ej8nonsense's Avatar
yeah me and buddy did the same thing in his crx. and be sure to mount it right.
Old Aug 28, 2006 | 11:54 AM
ludesrv's Avatar
Default Re: is it safe if i move my battery back? (ej8nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8nonsense &raquo;</TD></TR><TR><TD CLASS="quote">yeah me and buddy did the same thing in his crx. and be sure to mount it right.</TD></TR></TABLE>
7 Bungee cords, 4 zip ties and a peice of cloth haha. I ghetto rigged mine, doesn't even budge an 1/8 of an inch on hard corners.
Old Aug 28, 2006 | 01:14 PM
gsxr1k05's Avatar
my buddy did a battery relocation using a kit from ebay. it was a generic kit that was like 80 bucks. came with battery box, hold downs, and power adn ground cables with all hardware needed. he ran the cables under the chassis of the car. he had an rx-7, but i dont think that matters. just find where u want to mount the battery, get a relocation kit, and run the cables. sense the crx is so small, its not hard to run the cables under the half car's worht of carpeting that is there. just would have to drill holes into the firewall for the cables. its what i plan to do when i do mine,
Old Aug 28, 2006 | 02:38 PM
menappi's Avatar
http://homemadeturbo.com/tech_...ation/
Old Aug 28, 2006 | 04:00 PM
Tippyman's Avatar
And a drycell battery. The gases released by conventional batteries is toxic, and shouldn't be trapped in your car, with or without the box. I have a optima red-top in my hatch, sitting where the spare should be, full sized spare mounted next to it .</TD></TR></TABLE>
U got pix?
Old Aug 28, 2006 | 04:03 PM
I Think faster than that, i ran a 13.4 (i know shitty) with just a gangster relocation and they never said ****
Old Aug 29, 2006 | 06:10 AM
arabian129's Avatar
Thanks guys. Damn dry cell batteries are expensive in my country .Cant i use a simple one?
Old Aug 29, 2006 | 06:14 AM
arabian129's Avatar
Default Re: (Tippyman)
you know, my location to place it, is exactly that. I throwed away my spare. If throttle body suck hot air ,,will that effect on performance? I removed my intake for turbo setup.
Old Aug 29, 2006 | 06:19 AM
ludesrv's Avatar
Default Re: (arabian129)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
U got pix?</TD></TR></TABLE>
I can get some tonight for you.
I Think faster than that, i ran a 13.4 (i know shitty) with just a gangster relocation and they never said **** </TD></TR></TABLE>
Sometimes they won't say anythign at a public event. But a real even they are tight on your ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arabian129 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys. Damn dry cell batteries are expensive in my country .Cant i use a simple one?</TD></TR></TABLE>
Unless you want to breathe toxic gas, no, you shouldn't use a conventional one. I got my dry cell for free (my brother won't need it in his race car).
89efDUSTY
11
Mar 2, 2007 04:51 PM
allmotorEG6civic
12
Sep 8, 2006 09:31 AM
EGinNY
Jul 7, 2006 01:23 PM
Power Rev Racing
60
Dec 14, 2005 09:09 AM
coupon
Jun 26, 2005 01:47 PM
