B16 won't go. DIZZY???
Old Aug 27, 2006 | 10:24 PM
LigerZeroWPC's Avatar
Default B16 won't go. DIZZY???
The other day my dizzy was making a whole lot of noise and so I cleaned it out. It had little pieces of something in it so I cleaned it. Also the dizzy had brown dust all over. SO it was fine until one night I got off the freeway and the car died. Check Eng light went on and code 4. I let it cool down. ohhh before that happened the rpm cluster dropped out and stopped working. It kicks in randomly. so then today I tried to drive and the car goes and then light comes on adn car dies idles and shakes. I gased it and it won't rev past 3000. it got worse. now It won't go. I gas it and doesn't rev. it tries to die and then idles low.so basically i can't go no where. it just shakes and jumps around. btw its obd 0. jdm b16a.
theres spark out the dizzy but not out the wires. its like its weak. I take out a spark wire and idle doesn't change. fuel preasure is great. so whats up???? why don't i have a tach? and why is it dieing? code 4? I need help fast. its a daily driver and schools acoming. thanks
Old Aug 27, 2006 | 10:41 PM
salman's Avatar
Default Re: B16 won't go. DIZZY??? (LigerZeroWPC)
a new dizzy will solve your problem,
Old Aug 28, 2006 | 02:56 AM
philkehn's Avatar
for your tach check your back up light fuse under your dash, and do not buy a dizzy try some different plug wires dont waste 300 bucks when you can end up spending 20 on wires check the small before the large, but then again it never hurts to replace old with new
Old Aug 28, 2006 | 03:23 AM
salman's Avatar
Default Re: (philkehn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">for your tach check your back up light fuse under your dash, and do not buy a dizzy try some different plug wires dont waste 300 bucks when you can end up spending 20 on wires check the small before the large, but then again it never hurts to replace old with new</TD></TR></TABLE>
get one from me for 150 shiped, perfect working condtion
Normally plugs wire are perfect, else if they look damage,
I have had the same problem, Every thing was ok, just replaced the Dizzy and spark was there,
Take out the Dizzy plug it and then rotate it, if the injectors clicks, then ur wiring is ok,
Good Luck
Old Aug 28, 2006 | 08:40 AM
Default Re: (salman)
you don't think its the ignition coil? what happens when that goes out?
Old Aug 28, 2006 | 12:01 PM
salman's Avatar
Default Re: (LigerZeroWPC)
when i changed the DIzzy i found that it was Ignation coil which was damage,
the main reason was IG coil
stumy10
Dec 1, 2014 09:50 AM
vsmhatched
Jul 24, 2007 04:06 PM
Lucky-13
Mar 19, 2007 07:35 PM
Lucky-13
Mar 19, 2007 03:25 PM
TegProject
Mar 4, 2007 06:28 PM
