Problem with Blinker
Old Aug 27, 2006 | 07:13 PM
CRX MASE's Avatar
Default Problem with Blinker
When i turn on my right blinker i hear a loud buzzing noise, and my blinker doenst work, the light for the blinker in the cluster lights up, but does not flash. My left blinker works just fine. What could be the problem?
Old Aug 27, 2006 | 07:33 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Problem with Blinker (CRX MASE)
Check your flasher in the fuse box under the steering column. Does it do it with the left signal as well? If not, it could be the switch itself in the steering column.
Old Aug 27, 2006 | 07:37 PM
CRX MASE's Avatar
Default Re: Problem with Blinker (wiZCo)
naw its just the right side, left side works fine
Old Aug 27, 2006 | 09:19 PM
philkehn's Avatar
hmm actually im having the same problem but i have a short somewhere (just an idea for you) but i actually blow my back up light fuse when i use my right blinker sometimes
blackmugensivic
Dec 27, 2008 06:19 PM
lude1888
Feb 26, 2007 04:46 PM
jdm82
Mar 4, 2006 05:51 PM
h22HatchEG
Feb 23, 2006 06:23 PM
2kGSboi
Aug 10, 2001 02:34 PM
