What happens when one Spins a Rod/bearing
Old Aug 27, 2006 | 04:02 PM
Baron55's Avatar
Default What happens when one Spins a Rod/bearing
OK, so what happens...and how does that happen?
Old Aug 27, 2006 | 04:39 PM
PrinceAli132's Avatar
Default Re: What happens when one Spins a Rod/bearing (Baron55)
I found this in the Type R forum, https://honda-tech.com/zerothread/1734378
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">It's referring to a rod bearing. When you put in new bearings on the crank end of the rod, the bearings are "clipped" to the rod. There is a small groove on both the rod and the bearing to keep the bearing from spinning. The crank itself spins as the motor turns as does the rod (sorta) and the bearing is between the two surfaces, but stationary in/on the rod. When you spin a rod, that bearing "spins" instead of staying in place. HTH and isn't to confusing. If you need better definition, send me a PM and I'll see if I can dig up some pics for you. </TD></TR></TABLE>
Ali
Old Aug 27, 2006 | 04:52 PM
Baron55's Avatar
so, what one has to do to make that happen?
Old Aug 27, 2006 | 04:54 PM
IHTFP's Avatar
Default Re: (Baron55)
overrev your motor..
run low on oil..
stuff like that i think
Old Aug 27, 2006 | 08:15 PM
B18CYAAA's Avatar
Default Re: (IHTFP)
overrev your motor, miss a gear
Old Aug 27, 2006 | 08:30 PM
Dartanian's Avatar
Default Re: (B18CYAAA)
Poor clearances, stretched rod bolts caused by overrevs, oil contaminants, oil starvation.
Old Aug 28, 2006 | 09:27 AM
Baron55's Avatar
well, if the oil pump failed...could that be it also...? But, are integra oil pumps known to fail???
Old Aug 28, 2006 | 09:28 AM
Baron55's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CYAAA &raquo;</TD></TR><TR><TD CLASS="quote">overrev your motor, miss a gear</TD></TR></TABLE>
ok but missing a gear only lets one rev while in neutral isnt it?
Old Aug 28, 2006 | 12:06 PM
Baron55's Avatar
bump
Old Aug 28, 2006 | 12:32 PM
gurgle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">
ok but missing a gear only lets one rev while in neutral isnt it?</TD></TR></TABLE>
Miss a gear as in going to a lower gear instead of a higher one. If you were already at or near redline, then your engine will now shoot way past redline. The rev limiter works by interrupting spark. It can't do **** in this situation.
Old Aug 28, 2006 | 12:37 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Same thing pretty much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">well, if the oil pump failed...could that be it also...? But, are integra oil pumps known to fail???</TD></TR></TABLE>
So is this, having the pump fail, worse then having little to no oil though,
You can fill up with more if it's low, but if the pump goes in the middle of somewhere,
and you don't catch it then .. that would be painful for your motor.
hardcore97
Apr 23, 2015 07:55 PM
AssPenny
13
Feb 22, 2014 07:51 AM
igorka_91
13
Jul 5, 2009 12:29 PM
dj-t
Jul 2, 2009 08:48 AM
