1995 Odyssey uses 1 quart of oil every 600 miles
Old Aug 27, 2006 | 02:00 PM
Fifth Honda's Avatar
Default 1995 Odyssey uses 1 quart of oil every 600 miles
Honda was leaking oil when purchased one year ago with 153k miles. It now has 211k miles because I drive it a lot of miles in my job. Replaced oil pan gasket, oil filter gasket, all three oil seals and valve cover gasket when I first got it. Runs great, gets 30 mpg, but still using oil. Recently check engine light has come on twice and it seems to idle a little slow on occasion. Quite a bit of oil exits the tailpipe now. Am going to change the pcv valve. Appreciate any ideas you might have.
Old Aug 27, 2006 | 04:30 PM
hondadude's Avatar
Default Re: 1995 Odyssey uses 1 quart of oil every 600 miles (Fifth Honda)
change the pcv valve, check to see if the old one still has the plunger and spring in it. if this isn't the problem repost for some more help or ideas
Old Aug 27, 2006 | 05:07 PM
Ihatecars's Avatar
Do a compression check, at that many miles the head may need servicing. Also check and clean the EGR runners and idle air control valve.
Goodl luck.
Old Aug 28, 2006 | 04:39 PM
Replaced the pcv valve. The old one was in pretty good shape. Compression was 150 145 130 150. Bad news is the plugs were covered in oil. Put in a new valve cover gasket kit. Read the replies to someone who posted a similar problem. Is there anything else to look at while I'm squeezing a few more miles out of this engine?
Old Aug 28, 2006 | 11:29 PM
Has anyone tried an envalve pcv valve? Supposed to eliminate blow by.
Old Aug 29, 2006 | 02:55 AM
Ross 2.0's Avatar
In a Junkyard near you.
if you dont see a reply from me later send me a PM. Or someone give instructions on how to use top engine cleaner.
i have to go
Old Aug 29, 2006 | 08:03 AM
ricebike's Avatar
to add: what were the trouble codes?
not directly related but helpful since your check engine light did go on...
Old Aug 29, 2006 | 09:11 AM
He didn't get a chance to check the codes. I looked at your pics, ricebike. Just about the same damage, same place as when i tagged a deer this summer.
Thanks for the help everyone.
Old Aug 29, 2006 | 12:59 PM
ck123's Avatar
how do u put 58k miles a year on a car? ?
Old Aug 29, 2006 | 03:29 PM
I am a contract employee for a company that transports adolescents and people unable to drive to healthcare appointments. I own the Odyssey.
kaivorth
Honda Civic (2001 - 2005)
Apr 2, 2015 04:11 AM
curtie94
Jul 9, 2011 09:16 PM
keilux
53
Aug 17, 2009 05:43 PM
EkFG
Mar 15, 2008 07:47 PM
djmatix
Feb 7, 2005 07:58 AM
