4th Gen H23 Fuel Pump Relay
Old Aug 27, 2006 | 01:55 PM
jds06eagles's Avatar
Default 4th Gen H23 Fuel Pump Relay
Cant find one anywhere... cannot find a fuse either.. im getting spark and everything else on the engine works but im not getting any fuel... pulled plug and checked it and im not getting any power with my test light... any help would be appreciated thanks
Old Aug 27, 2006 | 02:03 PM
SKDRCR's Avatar
Default Re: 4th Gen H23 Fuel Pump Relay (jds06eagles)
Which plug did you pull, the one by the steering column?
Old Aug 27, 2006 | 02:05 PM
Default Re: 4th Gen H23 Fuel Pump Relay (SKDRCR)
i pulled plug in the trunk under the plate that runs to the fp...
Old Aug 27, 2006 | 02:08 PM
SKDRCR's Avatar
Have you checked the main relay for the fuel pump?
Old Aug 27, 2006 | 07:16 PM
lude of pre 2.3's Avatar
go to honda and get a print out of where the relay is at. it should be under the steering column. i doubt that relay is bad could be wrong but i have never seen a bad fp relay on a honda. check for any broken wires and use your meter to test for continuity in the power wire running back to your pump. if you have continuity then i would make sure that you have power to the relay b4 you replace it not a cheap part. good luck man
Old Aug 28, 2006 | 05:04 AM
hp92lude's Avatar
Default Re: 4th Gen H23 Fuel Pump Relay (lude of pre 2.3)
theres a pic of where its located here
Main Relay Repair Writeup
ruben6805
Apr 19, 2013 10:26 PM
Arch-Angel
Feb 23, 2008 10:25 PM
gsrt nick
Oct 23, 2006 06:43 PM
IloveNewt
May 12, 2003 06:08 PM
