My JDM ITR steering wheel is loose.. how do i tighten it..
Old Aug 27, 2006 | 01:38 PM
J.nguyen's Avatar
Default My JDM ITR steering wheel is loose.. how do i tighten it..
i got a 95 RS /w a JDM ITR non SRS steering Wheel. and its not tight.. like if i were to use a little force on it to rock it up or down it moves, feel slike its not tight on the column or whatever. so i tried removing those 6-8 alan head screws and the middle thing but no luck theres another piece blockin it. how do i tighten my steering wheel down?
Modified by Jesse. at 11:31 AM 9/8/2006
Old Aug 27, 2006 | 02:23 PM
AdeJong 03's Avatar
i believe if you try to remove the main piece in the middle you should have access to the 19mm bolt that loosens and tightens the steering wheel
are there any torx bolts on the side of the middle piece? (the entire piece)
Old Aug 27, 2006 | 02:25 PM
J.nguyen's Avatar
Default Re: (AdeJong 03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdeJong 03 &raquo;</TD></TR><TR><TD CLASS="quote">i believe if you try to remove the main piece in the middle you should have access to the 19mm bolt that loosens and tightens the steering wheel
are there any torx bolts on the side of the middle piece? (the entire piece)</TD></TR></TABLE>
i remove dthe middle piece. then removed the little button for the horn. then i just see a black surface that i cant move out of the way and there are no screws / bolts to unloosen.
Old Aug 27, 2006 | 03:23 PM
vladd's Avatar
Default Re: My JDM ITR steering wheel is loose.. how do i tighten it.. (Jesse.)
i'm guessing the piece in the middle is screwed in the same place the airbag would be. pop off 2 little covers on the sides of the steering wheel and you should see a couple screws on each side holding the middle piece in. once you get that taken out you'll see the big 19 mm nut holding the steering wheel on.
Old Aug 27, 2006 | 03:34 PM
caymanjdm97dc2's Avatar
just remove the whole T section of the steering wheel n u will have alot of acces to the 19mm bolt that keeps the sterring wheel in place. the T section of steering wheel staps rite back in place very easily
Old Aug 27, 2006 | 03:42 PM
Old Aug 27, 2006 | 03:48 PM
J.nguyen's Avatar
Default Re: My JDM ITR steering wheel is loose.. how do i tighten it.. (caymanjdm97dc2)
wow thakn you.. for picture and instructions. now i just pull the pieces out and it comes right off? or will i have to remove the top iece of the steering colum first?
Old Aug 27, 2006 | 04:46 PM
didn't u say that the clip 4 the horn was behind the center cap so just take that off first n unclip it n then take off the t section afterwords...it comes very easy
Old Aug 27, 2006 | 04:48 PM
J.nguyen's Avatar
allright thanks. ill try this.
Old Aug 27, 2006 | 04:52 PM
importdude2000's Avatar
god dam u got mad problems
i hope u paid 1/2 price for the car
yo do u know how 2 install a autometer tach
Old Aug 27, 2006 | 04:55 PM
J.nguyen's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">god dam u got mad problems
i hope u paid 1/2 price for the car</TD></TR></TABLE>
dude i had to basically fix everything in this car..
Old Aug 27, 2006 | 05:06 PM
OMG THE GOGGLES's Avatar
Default Re: (Jesse.)
Good luck with everything, but that view is nice considering she was once an RS. Nice interior ideas so far man.
Old Aug 27, 2006 | 06:43 PM
honda genome
Guest
Posts: n/a
you should take it back to the ************ you bought it form and run his bitch *** over with the car!
Old Aug 27, 2006 | 07:10 PM
Tizight's Avatar
How do you drive the limit with that guarding your speedometer
Old Aug 27, 2006 | 07:51 PM
J.nguyen's Avatar
Default Re: (Tizight)
by remember what KMPH = iN US. ahha. and by RPM's
Old Aug 27, 2006 | 09:17 PM
AdeJong 03's Avatar
dont need to remove the steering column plastics
once the T section comes off, the nut should be visible
Old Aug 27, 2006 | 09:42 PM
J.nguyen's Avatar
Default Re: (N1 Wan)
Thanks everybody. Got it done! made a world of a difference after tigehtning that.. my steering wheel is actually STIFF!! wonder if it will make my driving alot easier and smoother then before
Old Aug 28, 2006 | 06:57 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Just rip the middle part off, It is velcored on the seams. THen you have access to the bolts. Make sure not rip off the horn wires. Don't literally rip it off, just take your times and feel around for hte seams and pull it apart from there.
McLude2nR
Jan 27, 2007 10:15 AM
dustin_crxsi
Oct 30, 2006 05:29 PM
haloseven
12
Jun 15, 2005 09:29 AM
b16acrxer
10
Dec 2, 2003 06:28 PM
zer0zer0 TypeR
Aug 6, 2002 10:07 AM
