DIY: Push Button Start
Old Aug 27, 2006 | 01:09 PM
SVOboy's Avatar
Default DIY: Push Button Start
Well, I was updating my site just now with it and I thought I might throw it up here since there wasn't DIY sort on it when I looked for it and I hadn't seen one since.
Anyway, here's the link to my site: http://www.crxmpg.com/pushbuttonstart.html
It's better on my site but this is the thread I made on another forum as I was doing it:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Have you ever wanted a push button start? I randomly did so I randomly hooked it up, pretty simple. Generally done with an S2000 engine start button from the olde honda dealership, but I went with just a standard button to save 35 or so bucks.
Parts:
1 SPDT (Single Pole Double Throw) Relay - 3.99 at my parts store
Some female quick connect ends - 2.99 at the parts store
Wire
Solder
1 Button of your choice
Tools:
Wire strippers and a screwdriver.
1. Check out this schematic and look at your SPDT relay, pretty simple. Figure out which wires are which and wire the stuff up.
2. Wire the **** in there crappily to make sure it works. Here’s mine half done:
Another shot with indications and all that on it.
3. Get your button and figure out how to mount it. I am going the way of small button skirted by washer and then mounted in my cigarette lighter hole. Here’s the washer pre mounting and painting. I hot glued, and burnt the **** out of my finger and leg.
4. I put this little cone over the button to paint the washer, o yeah.
5. Burn yourself.
6. Painted shots, looks decent to me:
7. Wrap your crippled, burning hand in wet stuff:
8. Mount up the button itself into the center console part.
Install will be finished tomorrow, piece of cake.
Update, finished the install with the new button, check it out:
Old Aug 27, 2006 | 04:35 PM
civhatch90's Avatar
is this just for bling purposes or is there anything else behind it?
Old Aug 27, 2006 | 04:49 PM
SVOboy's Avatar
Mine's for bling but you could hide the switch as a theft protection thing if you so wished.
Old Aug 27, 2006 | 05:27 PM
Tippyman's Avatar
Is the key still neccessary? Like do you have to turn the key all the way AND hit the button at the same time?
Old Aug 27, 2006 | 05:32 PM
bobkennedy's Avatar
Default Re: (Tippyman)
surely it takes out the last turn of the key or else whats the point?
Old Aug 27, 2006 | 05:34 PM
SVOboy's Avatar
Put the key in run and hit the button. Turning it to 3 doesn't do anything. I didn't want to eliminate the key completely, though I've seen it done in show cars and such.
stackedhouse
Audio / Security / Video
20
Nov 22, 2016 01:45 PM
b16rex_02
Feb 22, 2014 04:42 AM
b16rex_02
Feb 24, 2009 11:59 PM
balleur
Jul 21, 2007 01:13 PM
civic-cpe
Apr 4, 2003 05:28 PM
