cyp code 9 ?
Old Aug 27, 2006 | 12:46 PM
crxvtecturbo's Avatar
* B A N N E D *
Default cyp code 9 ?
i have a 1991 crx dx with auto to manual swap with b18 vtec and it has a obd1 conversion with hondata s200b with p28 ecu my problem is that with this cyp code my car feels like it is running on one cylinder as soon as i try and start it has a solid light and i have to hold the gas to the floor to get it to run when we were wiring it up for mpfi conversion is it possible if the cyp wires were switched that it fried the distributor any help would be greatly appreciated
Old Aug 27, 2006 | 01:13 PM
salman's Avatar
Default Re: cyp code 9 ? (crxvtecturbo)
Old Aug 27, 2006 | 01:14 PM
SVOboy's Avatar
You could just have the wires switched. I did this during my wire tuck. Try switching them/new dizzy.
Old Aug 28, 2006 | 01:26 PM
* B A N N E D *
Default Re: (SVOboy)
is it possible my ecu went bad
Old Aug 28, 2006 | 01:40 PM
SVOboy's Avatar
Perhaps. I had that happen but that was just I left the case off and a hot wire got in there,
Old Aug 28, 2006 | 01:42 PM
* B A N N E D *
i just bought a distributor should be here soon i am going to start there
Old Aug 28, 2006 | 06:48 PM
* B A N N E D *
Default Re: (crxvtecturbo)
Old Aug 28, 2006 | 09:36 PM
salman's Avatar
code 9= disconnected sensor,
which mean the ECu is not reading from the sensor, In OBD1 the wire are b15 and b16,
there is a posiablity that u might hqave connected them worng,
recheck,
Old Aug 29, 2006 | 12:50 AM
NikoZai's Avatar
Default Re: (salman)
it would not "fry the distributor" if the wires were switched but most imported engines or engines that have been sitting for a while have corrosion inside on the igniter unit.
This can cause every distributor code to be thrown.
I'm not saying all at once, just random poor signal on CKP, CYP, & Igniter
Sometimes scrape'ing the igniter unit connections helps, most times you just have to replace the distributor.
It's entirely possible you connected the wires backwards. That would be my first check before trying another dizzy.
If your computer were bad, you would probably have more problems than just CYP
Old Aug 29, 2006 | 09:11 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">code 9= disconnected sensor,
recheck,</TD></TR></TABLE>
the car is still obdo with obd1 conversion harness it is b10 and b12 for obdo
Old Aug 29, 2006 | 05:23 PM
* B A N N E D *
Old Sep 2, 2006 | 12:05 PM
* B A N N E D *
any more suggestions
crxvtecturbo
Aug 27, 2006 10:23 AM
tgh22a
11
Apr 17, 2006 03:56 PM
Touge Tuning
Feb 10, 2006 09:35 PM
gutted
24
Oct 5, 2005 08:11 AM
shivern
Mar 6, 2005 03:23 PM
