b16 linkage?
hi guys. im doing a b16 sir gen 2 swap into my 93 civic lx sedan. trying to hook up the shift linkage and for some reason its too short. i got the shift linkage with the swap so i assume its b16 linkage. is this linkage supposed to work or do i still need hasport or integra 94 + linkage? thanks. also, is avid linkage any good?
The shift linkage I got fit my eg hatch. I am not sure that it would fit your sedan though. The sedan is longer which would explain why its too short. Im not sure that the 94+ integra linkage will work either. Ill try to find you an answere.
From what I was able to find the 94+ integra linkage will work. They might have sent you the wrong shift linkage. If you can take a pic of it and I will tell you if it looks right or not. They usually also mark on the shift linkage what its for. See if you can find anything.
thanks man.
ill take a pic tomorrow as i cant today. ill also look for markings.
both rods on the linkage are almost the same length as well.
i can get the shift rod on the tranny but doesnt shift right (too tight)
and the other rod kinda looks like this: (this isnt an actually pic of my car)
http://hondaswap.com/attachmen...8.jpg
its about 6" or so away from attachment point.
thanks.
thanks.
Its me DUB
Mar 2, 2007 08:42 AM
