6th gen V6 ATF
Old Aug 26, 2006 | 11:22 PM
pos_cd5's Avatar
Default 6th gen V6 ATF
how many quarts of ATF does the 99 V6 auto. trans take? and what type of ATF does it use? also, is there any particular brands you guys recomend?
Old Aug 26, 2006 | 11:43 PM
YeuEmMaiMai's Avatar
Default Re: 6th gen V6 ATF (pos_cd5)
Slightly under 4. You MUST check the trans fluid with the car warmed up and the engine off. There will not be any on the dipstick if you check it with the engine running and you will end up overfilling it.....
Old Aug 27, 2006 | 12:36 AM
iam7head's Avatar
Default Re: 6th gen V6 ATF (YeuEmMaiMai)
complete flush/rebuilt/just drain and flush?
oem atf is the only way to go
Old Aug 27, 2006 | 01:09 AM
Default Re: 6th gen V6 ATF (iam7head)
drain and fill. I would not flush those units.............
Old Aug 27, 2006 | 06:06 AM
Eddiebx's Avatar
how do you manage to get 4qts in there, when its spec'ed at 3.1qts for drain and fill. i've always threw in 3qts on drain and fills and the level was fine.
Old Aug 27, 2006 | 12:31 PM
hondadude's Avatar
3 [three] quarts of Honda Z-1 ATF
Old Aug 27, 2006 | 04:42 PM
pos_cd5's Avatar
Default Re: 6th gen V6 ATF (hondadude)
how much is a quart of honda ATF?
Old Aug 27, 2006 | 04:44 PM
hondadude's Avatar
I'm not sure because I haven't paid retail for the last 20 years. LOL I'll guess around $6 a quart
LSteggyguy
Jul 22, 2014 04:14 PM
hnd
Dec 20, 2012 07:53 PM
Jaz760
Sep 9, 2012 02:21 PM
halfkoreanboy
Aug 7, 2011 06:40 PM
Ronin Integra8
Dec 12, 2002 01:13 PM
