99 civic cd player in a 98
Old Aug 26, 2006 | 09:24 PM
Tronski's Avatar
Default 2000 civic si cd player in a 98? Help
OK i just picked one up for a small fee. before i do anything i wanted to know if it will work? cuz i looked at the back of the deck and it doesnt look like the oem connector. is there anyway of installing it without hacking the harness?
Modified by jshealey at 10:42 PM 8/26/2006
Old Aug 26, 2006 | 11:13 PM
im done's Avatar
Default Re: 2000 civic si cd player in a 98? Help (jshealey)
get the "blue" plug and buy a radio harness at walmart for like 7 bucks. wire it up and plug it in
Old Aug 27, 2006 | 07:09 AM
fcm's Avatar
fcm
Old Fart
Get this plug for the HU... http://www.scosche.com/scosche...A08RB and this one for your car... http://www.scosche.com/scosche...HA02B
Connect the 2 harnesses together, [color for color] and it's plug and play, however there are a few other things you have to take into account...
1- The face of 99/2000 HU is diff. then your 98, an aftermarket kit will fill in the gaps.
2- If your 98 has key-less entry, you will have to stuff the 98 HU behind the dash and leave it connected, this harness is needed... http://www.scosche.com/scosche...HA07B
You will also need this jumper plug so your dome light works... http://www.scosche.com/scosche...HA03B
If you do not have key-less you should only need the jumper, you can also just add an aftermarket key-less or an alarm and wire the door locks, then you don't need to keep the 98 HU.
3- Mounting of the 2 HUs is done differently, the 99/2000 is an "ISO" type mount and your 98 is a rear mount, this should help...
http://www.installdr.com/Insta....html
It's not that it can't be done, but it means you have to be a little creative. 94
Old Aug 27, 2006 | 06:13 PM
Tronski's Avatar
kool thanx guys got it installed but now how do i set the time on the radio?
Old Aug 28, 2006 | 04:04 PM
progoon's Avatar
Kool post i needed to know this too.
Old Aug 28, 2006 | 07:39 PM
Tronski's Avatar
Default Re: 2000 civic si cd player in a 98? Help (progoon)
come on someone help us out
bkrayjr
Audio / Security / Video
Oct 20, 2008 06:12 AM
apm
Apr 11, 2008 09:20 PM
pnthr30
Jun 27, 2006 01:24 PM
pearl
14
Mar 12, 2005 07:07 PM
