how can i tighten my clutch?
How can i tighten my clutch? i had a new clutch installed about one month ago, and now it feels soft to me...How can i tighten it? in the cockpit or do i have to go into the motor?
how soft/hard it is depends on the stiffness of the pressure plate. the only thing you can adjust is where it grabs if its grabbing to high loosen the adjuster , and obvoisly if it grabbing too low tighten the adjuster(which is a plastic piece in front of the transmission that the cable runs through)
did you resurface your flywheel when you changed the clutch?
theres a small rubber piece at the end of your clutch cable...ring a matching sized hose clamp around it and tighten it down...this should give you a more direct feel from the clutch
SSJSubgeta
Oct 22, 2005 12:20 PM
