HOOD GAP!
Old Aug 26, 2006 | 06:53 PM
integraa972's Avatar
Default CRX HOOD GAP!
ANY1 KNOWS HOW TO FIX IT?!?!?
IS THE HOOD OR WAT?
Old Aug 26, 2006 | 06:57 PM
RockWolf's Avatar
Default Re: CRX HOOD GAP! (integraa972)
Well one maybe the center pin is maybe too long. I has a spring around it and a slot to put a screw driver and adjust it.
Also there is some rubber screws on each front corner that can be adjust it.
Old Aug 26, 2006 | 06:59 PM
CRX_1.8T's Avatar
Which part of your hood has a gap?
Old Aug 27, 2006 | 02:39 PM
idk ... i've tried to fix it but **** still looks the same.
its only on the driver side.
Old Aug 27, 2006 | 03:16 PM
1 Fly SI's Avatar
Has the car ever been wrecked on the front? If so the hinges could be bent.
Old Aug 27, 2006 | 03:22 PM
vtecn8ive's Avatar
Default Re: CRX HOOD GAP! (1 Fly SI)
looks like the bumper is off line too. look at the fender/bumper gap. My guess small front end damage.
Old Aug 27, 2006 | 03:32 PM
SD_Lurker's Avatar
HT White Ops
Loosen your driver side fender and push it in.
Old Aug 27, 2006 | 04:00 PM
DelSolDon's Avatar
Default Re: CRX HOOD GAP! (nicks_jdmstyle_ef9)
looks to me like the headlight needs adjusting up
Old Aug 27, 2006 | 05:00 PM
nah its never been wrecked...and yea the bumper looks loose because i took it off and just put it on and not screwed in...yea it might be the headlight n fender but how do you adjust the headlight?
Old Aug 27, 2006 | 05:29 PM
HackeN's Avatar
Default Re: (integraa972)
id loosen the fender and bring it up a bit. those headlights should have a screw you can turn with a phillips screwdriver. Use one with the right size point, or it may strip the screw and then that would suck bad. Mine were stripped on the adjusters when I had my catch :/
Old Aug 29, 2006 | 11:40 AM
DelSolDon's Avatar
Default Re: (HackeN)
actually it looks like it is more than just the screw adjustment. might want to make sure that the two bolts (10mm head) are in the top of the headlight bracket, and if they are, then loosen them and adjust it that way.
Old Aug 29, 2006 | 01:18 PM
andrey320's Avatar
The hood has rubber bump stops that can be adjusted
centraldriver29
Aug 16, 2018 05:15 AM
supracrx
Paint and Body
Jun 11, 2009 12:47 PM
jdmazm
Sep 20, 2006 07:20 PM
LagunaSecaEG
Jul 20, 2006 12:02 PM
