Tire balancing? Alignment? Help...
I've searched, but nothing came up helpful for me.
I had rims and my steering wheel was fine... It didn't shake or very minimal shaking. I had my alignment done not too long ago, like 2 months ago I suppose
I put on my stock tires today and had them balanced before I put them on, but now my steering wheel shakes when I drive at 40+ speed.
Is this caused because my balancing was not done correct?
Thanks in advance for the help if any.
have the shop rebalance your tires and wheels .......normally if it only shakes at certain speeds and goes away at higher or lower speeds it a balance issue!!!!!!!
I was thinking that might be the issue. Hopefully everything works out and they agree on rebalancing them again.
If that's correct, then I think that's the problem. Thanks.
Modified by FutureITR at 10:33 PM 8/27/2006
Got it done today. Balancing was done right.
When I had rims on, I had some spacers. And for some reason 1 spacer was stuck on the brake portion and had it checked out. Everything runs fine now, thanks for the input vtecsi00
exz0n-.-
Nov 27, 2008 12:19 AM
Nizzy
Aug 21, 2003 07:31 AM
