crank bolt removal tool??
Old Aug 26, 2006 | 03:42 PM
vrrodri's Avatar
Default crank bolt removal tool??
I hear that there is a tool to remove the crank pulley bolt when changing the timing belt. Anyone knows where I can find this tool? I have a 7th Gen hatchback.
Thanks
Old Aug 26, 2006 | 04:59 PM
atg1290's Avatar
Ive seen it at....sears, summit racing, advance auto, and autozone. To make life hella easier get some air tools and be done with it
Old Aug 26, 2006 | 06:40 PM
vrrodri's Avatar
I agree that ideally air tools is the way to go, until I can get them, I have to find the best way to get the job done...I will check Sears and autozone again--did not see them last time.
Old Aug 26, 2006 | 07:46 PM
MarcoLaMont's Avatar
Default Re: (vrrodri)
Just a word of warning, I don't know the exact torque spec but the bolt is on there tight. If you plan on doing it by hand you need a breaker bar/extension 3-4ft long or enough room to jump on a smaller bar with all your weight. I had my engine out when I did it, I used a 2ft breaker bar and had to jump on the bar 4-5 times to get it to break loose.
I would highly advise finding someone with some air tools OR got to a harbor tools/Northern and they have an electric impact gun for $30-$40
Old Aug 27, 2006 | 11:24 AM
adrenajunky's Avatar
Default Re: crank bolt removal tool?? (vrrodri)
i have a 1000fpt impact gun and i still couldn't get mine off. i ended up ordering the tool that ur talking about and a 2ft breaker bar and problem solved. i dont remember where i got it, i ordered it online from like tool warehouse or somthing like that
deckster333
May 12, 2018 05:38 AM
tinyscivic
Feb 27, 2010 10:25 PM
Teg_93
Jan 15, 2007 06:55 AM
MajorPayne
Jul 2, 2004 07:06 PM
MCP486
Apr 1, 2003 09:48 AM
