brand new b16a idle fine sounds fine but no power HELP!!!!
Old Aug 26, 2006 | 02:59 PM
kalani5969's Avatar
Default brand new b16a idle fine sounds fine but no power HELP!!!!
ok i just built a b16a it has a type r intake but dont know if thats the problem port and polish ok but its running no codes idles fine sounds fine still needs to be broken in but when i drive it it has no power like 90 hp it feels like 3000 pounds is behind it dosent spudder or anything vtec hit hard sooo weird please HELP and it dosent make any binding or grinding no smoke no weird smells HELP HELP HELP
Old Aug 26, 2006 | 03:15 PM
civhatch90's Avatar
if you used punctuation it would be much easier to understand
Old Aug 26, 2006 | 03:33 PM
blumpfish's Avatar
Default Re: (civhatch90)
sounds like its fine to me.. its a b16 dude.
Old Aug 26, 2006 | 04:21 PM
kalani5969's Avatar
Default Re: (blumpfish)
iv had a b16 before this is slow HELP
Old Aug 26, 2006 | 04:28 PM
salman's Avatar
damm,
Ill say, just drove it for few miles and ill be ok,
Old Aug 26, 2006 | 05:39 PM
mechaniclease's Avatar
You said that you've just built it ??May be good to check your timming belt first,could be off by a touth !
Old Aug 26, 2006 | 05:41 PM
RockWolf's Avatar
Default Re: (mechaniclease)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mechaniclease &raquo;</TD></TR><TR><TD CLASS="quote">You said that you've just built it ??May be good to check your timming belt first,could be off by a touth ! </TD></TR></TABLE>
Yeah check your timing because it makes a huge difference. even by a tooth.
Old Aug 26, 2006 | 07:07 PM
88 rex's Avatar
Default Re: (RockWolf)
If his timing was off it wouldn't idle like normal. Just sounds like a normal B16 to me. They aren't lightning fast in stock form.
Old Aug 26, 2006 | 08:01 PM
kalani5969's Avatar
Default Re: (88 rex)
i understand that but its been balanced, ported, type r manifold, comptec headers, gears, cams, its brand new its been down the road and back and idle for 20 min. its something dont know what what could it be? put it this way it takes about 4to 6 sec to even hit 5k fron a rolling start thats bad. if anyone has any suggestions on what it is let me know thanks.
Old Aug 26, 2006 | 09:15 PM
RockWolf's Avatar
Default Re: (kalani5969)
how is it when you rev it without in gear?
also i had my timing belt change on my car. and it idled fine but didnt have any power.
Then we brought it for some timing. payed 160$ and the car was faster then before the timing belt change. (its all about timing)
Old Aug 27, 2006 | 02:18 AM
Suck my DX's Avatar
tuned?
Old Aug 27, 2006 | 05:17 AM
saikouEF8's Avatar
Default Re: (Suck my DX)
losing power is obviously a sympotom of something wrong or something thats about to be really wrong... i would check all your grund wires. when i had a loss of power my thermostat groud was loose which cause my fuel pump to work intermittently until one day it just stopped working. just go over everything and just make sure everything is nice and tight. sometimes the little **** makes a big difference
Old Aug 27, 2006 | 07:36 AM
kalani5969's Avatar
Default Re: (saikouEF8)
umm it its definity somthing in the motor the revs take a while to. no its not tuned got a skunk chip havent messed wit anyting else. the only thing it might be is my fuel filter the line that goes to the rail leak a little at the top of the filter. and ive redone the timing so its not that. the motor idles fine sounds fine just feels like theres alot of weight on the crank or its pulling 3000 pounds
Old Aug 27, 2006 | 07:57 AM
mahatma's Avatar
try having a look at your throttle body with the intake tube off.....make sure it's rotating almost the full 45* when you mash the gas.
check the throttle cable too, make sure there's no slack....
maybe you built the engine REALLY tight....?
Old Aug 27, 2006 | 08:42 AM
88 rex's Avatar
Default Re: (mahatma)
Lots of good advice.
Check the throttle and calibrate TPS.
Get tuned!
Did you build the bottom end?
Old Aug 27, 2006 | 11:14 AM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kalani5969 &raquo;</TD></TR><TR><TD CLASS="quote"> no its not tuned got a skunk chip </TD></TR></TABLE>
are u serious?!?!?!?! you just spent all that time and money building your motor,and your going to throw it all away just cuz your not going to tune it...
skunk and any other preburned chip is going to be junk...doesnt matter the setup...
hate to break it to you,but you are in dire need of a tune...i can already see you are running the motor hard,and thats one of the worse things to do on an untuned motor...spend the money and get it tuned...or else you are going to be very sorry very soon..
Old Aug 27, 2006 | 01:01 PM
kalani5969's Avatar
ok what do u mean get tuned? ok i ran the motor today and it ran about 35% stronger than yesderday. i drove about 6 miles i was driving it soft no higher than 5k right before vtec 4500k it would spudder maybe that could be some of it? and when i parked the seal fron my oil pump that goes around the crank shaft was leaking alot like half a quart of oil that could be it to if any of u have any advice please say something and how soft should i run the car when break in thanks
Old Aug 27, 2006 | 01:13 PM
90b20vteckidd's Avatar
ok well first your problem is the fact that its a b16. you seriously need to go get it tuned. that could be your problem. it also sounds like your timing is off. and no, i would not drive the car with that crankshaft seal out. thats a lot of oil to lose.
good luck, and remember. its just a b16. dont expect too much out of it
Old Aug 27, 2006 | 03:39 PM
philkehn's Avatar
a b16 has alot of power compared to a hf dx or si, if you cant keep up to one then your engine is having problems, like everyone said check your timing first, grounds, maybe even your vacuum lines.... etc look over the small stuff
93H22
Mar 13, 2008 11:32 AM
(VTEC_FANATIC)
11
May 28, 2007 12:26 AM
ppl talk bout my old name
Nov 12, 2005 12:12 PM
pkripper
Jul 1, 2005 05:45 PM
redED9Si
Apr 30, 2005 09:10 AM
