Megan Header...?
Guest
Posts: n/a
I am looking into buying a megan header as an aftermarket replacement for my cracked h22a header until I can get a rmf, smsp, etc. I know my current header has a flexpipe and was wondering why this Megan header does not and will it make a difference?
http://cgi.ebay.com/ebaymotors...wItem
not sure why it doesn't have the flex pipe, but a friend of mine bought one of those headers just for a replacement when he did his motor swap, and he says it works just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 Sleeper »</TD></TR><TR><TD CLASS="quote">i got one and it did have one...i think it might just be a picture of a product not for necessarily your application </TD></TR></TABLE>
I have one, it also has a flex pipe.
Remember, don't connect the support to the back of the block.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi »</TD></TR><TR><TD CLASS="quote">
Remember, don't connect the support to the back of the block.</TD></TR></TABLE>
Why do you say that? I think I read somewhere that it will rip it off or something like that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 »</TD></TR><TR><TD CLASS="quote">Why do you say that? I think I read somewhere that it will rip it off or something like that?</TD></TR></TABLE>
That's correct.
Modified by mkazm83 at 11:26 AM 8/26/2006
That's correct.
yea i had the support bolted to the back of my block, dont know when or how it happened but about a month after the install i crawled under car and the support was broken in half. why bother
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx »</TD></TR><TR><TD CLASS="quote">yea i had the support bolted to the back of my block, dont know when or how it happened but about a month after the install i crawled under car and the support was broken in half. why bother
mine is broke in half now also
</TD></TR></TABLE>mine is broke in half now also
Mine cracked and I had it re-welded. I went through this process several times in few thousand miles. When mine would break it would pull away from the pipe and cause a huge exhaust leak. Since removing the braket, I've had no problems and it's been 12-15k miles now.
