Head TDC help
I got a Head that was uninstalled from a LS and well i dont think the cams where put back at TDC where should the valves be at TDC for a LS b18b Head??? Need a Pic or a some description how to kno
I believe, but Im not sure, that there are distinctive marks on the camshaft gears. Like little grooves or notches different from the gear teeth themselves. Either that or a line on one of the outside part of the teeth. Line those 2 marks or lines up on the intake and exhaust side, pointing torwards each other, and it will set them at TDC.
That is how it was on my Eclipse GS-T, and my Saturn, so I am assuming that is correct. But I have not set time on a Honda, other than clocking of the distributor as of yet. But I hope that helps.
daboy155
Jun 3, 2018 11:57 AM
