oh, snap... i broke it all
Old Aug 26, 2006 | 12:04 AM
misha's Avatar
Default oh, snap... i broke it all
I was puting my front wheel back on, and one of the bolts just snaped, i figure ok, i can fix it later, should be fine to drive it like this for a day. So then next bolt to it, snaped to, when i tightened it. I was kinda shoked. So i wanted to fix it, and try to take it all apart.
Well, then i tried to undo the bolts that hold the caliper braket, they came right out with the threds, that were inside of the braket. Then the bolts that hold the caliper broke too. Only the top one actually.
I should be able to fix it tomorrow, if ill find parts quick.
long story shot, for the future, how can i tighten the lug nuts so i dont break it. Just with the normal wheeel wretch??? about 2.5 feet long( pretty strong too)
sorry to keep this long
did this happend to anybody before?
Old Aug 26, 2006 | 12:42 AM
RexShop's Avatar
Don't torque them so much.
Old Aug 26, 2006 | 01:36 AM
misha's Avatar
Default Re: (RexShop)
yea, but it didnt seem like it was to much. well may be a little bit, but it never hapend b4
Old Aug 26, 2006 | 01:40 AM
god.loves.ugly
Guest
Posts: n/a
Default Re: (misha)
do you have a torque wrench?
Old Aug 26, 2006 | 01:43 AM
misha's Avatar
Default Re: (God.Loves.Ugly)
nope, just some wheel wrench.
looks like this
http://www.screwfix.com/sfd/i/...l.jpg
Old Aug 26, 2006 | 07:22 AM
thesmogman's Avatar
Default Re: (misha)
If you go over 80ft.lbs. on the lugs you will snap them. Plus you might crack the rims too.
Yes it is the same for stock alloys and aftermarket wheels.
Old Aug 26, 2006 | 07:37 AM
VRD^don's Avatar
Default Re: (thesmogman)
torque wrench is your best friend..
Old Aug 26, 2006 | 02:21 PM
DC_RaceR's Avatar
Default Re: (k_motor)
stop using STEROIDS....
Have fun with those bolts.
Junk yards should have plenty of bolts.
but for the wheelstuds get new ones.
Old Aug 26, 2006 | 03:17 PM
civhatch90's Avatar
my wheel wrench is a foot long and i never broke anything. yours being 2.5 feet might be a little long and you are applying too much torque
Old Aug 26, 2006 | 03:26 PM
HondaHeddie's Avatar
Default Re: oh, snap... i broke it all (misha)
wtf
2.5 ft!!!!!!! no wonder you are snapping things
are you using your Hummer tools??????????????????????
why werent you using the honda wrench that came with your car??????(16" or less)
it will torque just fine bout 1/8 rev with foot after peak hand torque and you are good to go
should hear a couple a pings as it seats THEN STOP
!!!!!!!!!!!!!!!!!!do not go past 1/4 rev after hand torque!!!!!!!!!!!!!!!!
unless you are michael J. .... then get a M A N to help
Old Aug 26, 2006 | 04:55 PM
misha's Avatar
Default Re: oh, snap... i broke it all (aal)
I fixed it today. 10 bucks, new bracket, new bolts. Didnt brake anything . didnt need a M A N to help me.
yes now i use like a feet long wrench, and no crazy power to it.
I just didnt know, will be carefull next time.
thanks
Old Aug 26, 2006 | 05:54 PM
bobkennedy's Avatar
what is the correct torque setting for the wheels on a crx?
Old Aug 26, 2006 | 05:56 PM
BlueCrxNC's Avatar
80 ft./lbs. I believe.. too lazy to look up.
Old Aug 27, 2006 | 08:46 AM
mahatma's Avatar
Default Re: (BlueCrxNC)
I always torque to 90 but I don't know what the spec is....
Old Aug 27, 2006 | 08:49 AM
ED7's Avatar
ED7
Default Re: (mahatma)
It is 80
Trevor Duncan
May 29, 2019 12:34 AM
chevyhonda
Apr 11, 2011 06:52 PM
paulzy
Welding / Fabrication
11
Dec 3, 2007 12:43 PM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
tC_Dragon
Jan 27, 2003 05:37 PM
