EG automatic to manual cluster swap
Old Aug 25, 2006 | 07:38 PM
Kilat29's Avatar
Default EG automatic to manual cluster swap
i did a auto to manual conversion, i finally got a manual cluster but the wire harness doens match the manul cluster. greed connector is different size.
anyone know how to sole this problem?
Old Aug 26, 2006 | 02:55 AM
BlueIntegraBoy's Avatar
Default Re: EG automatic to manual cluster swap (Kilat29)
There's no place for the gear indicator light plug. You only need to use the 10-pin and 13-pin grey plugs (as well as your yellow SRS plug).
Old Aug 26, 2006 | 08:57 PM
Kilat29's Avatar
Default Re: EG automatic to manual cluster swap (BlueIntegraBoy)
what about the green connector?? the automatic is bigger. than the manual green
connector. i assume that the green connector is the drive indicator, but then what is the green connector for the manual cluster? because i want to use the tach on the manual cluster. do i just use the connectors that you tell me to use and the tach will work?
Modified by Kilat29 at 10:27 PM 8/26/2006
Old Aug 27, 2006 | 12:11 AM
Yes, use only the 10-pin and 13-pin plugs. The other small green one is the cruise control, which yours might not have.
Old Aug 27, 2006 | 08:55 AM
Kilat29's Avatar
ok, i'll try that then, thankz. i'll let you knoe how it comes out.
Old Aug 27, 2006 | 09:34 AM
Chumbas_EG9's Avatar
^ya its most likely not needed. as the previous poster has stated^
Old Aug 29, 2006 | 08:10 PM
Kilat29's Avatar
it worked. thanks
dirtycolombian
Jun 10, 2007 09:27 PM
thedirty-Dseries
Apr 15, 2006 06:27 PM
jazz215
Sep 23, 2005 08:31 AM
shadykit
Feb 4, 2005 05:16 PM
B2FiNiTY
Dec 18, 2002 09:51 AM
