EG automatic to manual cluster swap
i did a auto to manual conversion, i finally got a manual cluster but the wire harness doens match the manul cluster. greed connector is different size.
anyone know how to sole this problem?
Re: EG automatic to manual cluster swap (BlueIntegraBoy)
what about the green connector?? the automatic is bigger. than the manual green
connector. i assume that the green connector is the drive indicator, but then what is the green connector for the manual cluster? because i want to use the tach on the manual cluster. do i just use the connectors that you tell me to use and the tach will work?
Modified by Kilat29 at 10:27 PM 8/26/2006
jazz215
09-23-2005 08:31 AM
