engine wont rev past 3,000 rpm
Old Aug 25, 2006 | 05:18 PM
goldhatchie89's Avatar
Default engine wont rev past 3,000 rpm
just got done putting a b16 in my friends crx the engine will start but wont rev past 3g like there is some sort of rev limit at 3g never ran into this before. checked all the basic stuff....could there be something seroiusly wrong? Any input would greatly help.
Old Aug 25, 2006 | 05:59 PM
bdavis's Avatar
Default Re: engine wont rev past 3,000 rpm (goldhatchie89)
you are in limp mode. its really bad. either you unplug a necessary sensor or you computers bad
search "limp mode"
Old Aug 25, 2006 | 06:06 PM
Default Re: engine wont rev past 3,000 rpm (bdavis)
limp mode? so either the ecu what sensor maybe the harness? thanks alot..
Old Aug 25, 2006 | 07:21 PM
And the CEL isnt throwing any codes....?..
Old Aug 25, 2006 | 07:57 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
try another ecu or see if the one u have has a chip in it
Old Aug 26, 2006 | 12:36 PM
Default Re: engine wont rev past 3,000 rpm (street dreams)
thanks guys ill give it a try..
Old Aug 27, 2006 | 06:31 PM
just got our hands on a new ecu..still the same problem..take back what i said about the cel codes we actually got a fualty ecu code and a cple others..put in new ecu only got code 21..still in limp mode i guess..checked the vaccum lines ok..im thinknig the dizzy is bad or maybe the map sensor any other input would help though..
Old Aug 27, 2006 | 06:33 PM
the old ecu we took out was the pr3 and the new one we put in was a pw0 if that helps anything..
Old Aug 27, 2006 | 07:01 PM
xsi-t's Avatar
Sounds like your ignitor chip is bad and/or CAS
Old Aug 27, 2006 | 08:00 PM
Default Re: engine wont rev past 3,000 rpm (xsi-t)
is there a code for the cas?
Old Aug 28, 2006 | 12:30 AM
trulunacy2786's Avatar
that sounds like your idle air control valve. i had the same problem and switched out that sensor and my car worked just fine.
XX3LXERAKOXX
Jul 8, 2017 08:20 AM
SolScifen
May 19, 2013 11:35 AM
GG-SquadDB
Mar 6, 2004 02:16 AM
msrrex
Nov 2, 2003 10:14 AM
