tranny or shift linkage HELP!!
Old Aug 25, 2006 | 05:13 PM
honcrx91si's Avatar
Default tranny or shift linkage HELP!!
i dont know what is wrong, but my shifter wont stay in place... i can change gears... but once i am in any gear i can still move the shifter all around.. is that b/c of my tranny or shift linkage? i dont think it could be the tranny but i dont know how it could be the linkage either please help asap.
Old Aug 25, 2006 | 07:34 PM
SVOboy's Avatar
Sounds like the linkage pin (or lack thereof) is the issue.
Old Aug 25, 2006 | 07:43 PM
crxsteve's Avatar
Default Re: (SVOboy)
uhm did you check the rubber hold thing that hold the shift still
check your shiftlink
do you have a adjustable or no ???
Old Aug 25, 2006 | 08:06 PM
honcrx91si's Avatar
Default Re: (crxsteve)
my linkage is non adjustable, and i couldnt get the pin back in so we used a nut and bolt and they are both still there... i can shift into every gear but once it is in gear i can move the shifter the whole way over to the other side and still be in gear and i can take it out of gear and put it in the gear it needs to go in however 5th and reverse are hard to get to i have to go over really far.... and also the linkage is called race tech it came with my mounts i dont know how good they are and i hit my exhaust when i put it in the the actual part that moves i cut off the back or like the balance wieghts i guess they are and im thinking thats the problem but i dont know im thinkin about just gettin hasport linkage i just want to make sure it not the tranny
Old Aug 25, 2006 | 08:12 PM
SVOboy's Avatar
It's the bolt then. Get a roll pen and a screwdriver that's just the right size and nail it!
Old Aug 25, 2006 | 08:24 PM
honcrx91si's Avatar
alright ill try that then thanks.
Hatchbacksonly
Dec 2, 2012 04:20 PM
dsd1_209
Transmission & Drivetrain
Nov 1, 2012 06:53 PM
B16aCRXSi
20
Nov 7, 2008 11:49 AM
VegaS10
15
Dec 13, 2005 03:28 AM
