stripped exhaust manifold threads
Old Aug 25, 2006 | 02:22 PM
a1320addict's Avatar
Default stripped exhaust manifold threads
One of my exhaust manifold bolt-hole threads has the slightest stripping right at the start of the thread.
Will a tap and die fix this?
Old Aug 25, 2006 | 02:23 PM
Leo C's Avatar
Night Owl
Default Re: stripped exhaust manifold threads (a1320addict)
Get some of that white grease that fixes stripped threads. I forgot exactly what its called.
Old Aug 25, 2006 | 02:26 PM
Default Re: stripped exhaust manifold threads (shutupnskate)
It's the threads in the head itself.
I plan on using loctite either way, my new head should be done relatively soon. I just wanted to do if a tap and die is what I need?
Old Aug 25, 2006 | 02:58 PM
95 integra's Avatar
A tap should fix it assuming you havent stripped it out and the threads are just a little damaged.
Old Aug 25, 2006 | 03:34 PM
Default Re: stripped exhaust manifold threads (95 integra)
Edit: Ran over to Sears and picked up the Craftsman Master Thread Restorer kit. Great product, very complete and fixed the situation without any aggravation. Was instructed by the salesman at Sears to not use a tap for this being the tap may start cutting into the existing threads.
Old Aug 25, 2006 | 03:37 PM
RHDintegXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Edit: Ran over to Sears and picked up the Craftsman Master Thread Restorer kit. Great product, very complete and fixed the situation without any aggravation. Was instructed by the salesman at Sears to not use a tap for this being the tap may start cutting into the existing threads.</TD></TR></TABLE>
goodstuff how did it work out for you?
Old Aug 25, 2006 | 03:40 PM
Default Re: stripped exhaust manifold threads (SINFULintegXsi)
As I said, it was really painless. Overall I hate Sears, they're staff usually sucks. But I had a really helpful salesman this time around, and actually learned a bit from our conversation.
The thread-restorer kit essentially cleans-up any nick or damage to the threads, while pulling the scraps out when you reverse it. I did about 4 passes with the tool using cutting oil, increasing it's depth each time. Finaly when I felt the bit bottom-out, I backed it out fully, and did one last pass. Worked absolutely perfectly
kingofnothing
Oct 15, 2008 06:19 PM
speedlabx2005
Oct 16, 2006 09:35 PM
dave@passenger
Welding / Fabrication
Aug 17, 2006 10:59 PM
roadawg
Jul 11, 2004 07:36 AM
P1mpSlap
Dec 23, 2003 11:00 PM
