few quick questions
vtec oil pressure plug has 2 wires right? i assume black is ground?
and what is the best way to solder them together? i read somewhre to wrap the solder around the wires after they have been connected and then shrink wrap them
oh yeah and can i just take my o2 sensor out and put it back in? or is there something that has to be done after its put back in?
When you wrap both wires together you will need to use a wire-end connector to keep the wires from giving out and spreading appart.
If you take out your o2 sensor, be carefull not to damage it and you can just put it back in without any problems
if you solder them together, you shouldn't need a splice connector, and yes you should use heat shrink. most of the guys i know put a little die-electric grease on the soldered parts before heat shrinking it just as a little extra protection against moisture.
blindsk8er1013
Sep 16, 2008 04:38 PM
