NEW HEAD GASKET car wont start!!!!!!!!!!!!
Old Aug 25, 2006 | 01:59 PM
frost_0ne's Avatar
Default NEW HEAD GASKET car wont start!!!!!!!!!!!!
i have a 1990 honda civic hatchback all stock no mods (commuter)
car was over heating and i drove on it for a ways to get home i changed the thermostat and head gasket to be safe and now my car will not start. timeing is at tdc checked firing order 3 times to make sure its right when i pulled the head off everything looked good no warping or nothing and the block looked fine as well. ive got spark and fuel. although i havnt checked for compression although the rings and sleeves looked alrite.. all my main grounds are connected..
if anyone can help id really appreciate it thanks in advance.....
Old Aug 25, 2006 | 03:26 PM
RCautoworks's Avatar
Default Re: NEW HEAD GASKET car wont start!!!!!!!!!!!! (frost_0ne)
How is the timing ?
Old Aug 25, 2006 | 08:51 PM
frost_0ne's Avatar
Default Re: NEW HEAD GASKET car wont start!!!!!!!!!!!! (90blackcrx)
top dead center ....
Old Aug 25, 2006 | 09:11 PM
C_R_X_V_T_E_C's Avatar
iz there any coolant/oil or anything on top of the pistons, or in the cylinders>?
its happend to me when i did a head gasket once.
Old Aug 25, 2006 | 09:38 PM
frost_0ne's Avatar
Default Re: NEW HEAD GASKET car wont start!!!!!!!!!!!! (C_R_X_V_T_E_C)
before i replaced the head i cleaned all the oil/coolent and gasket material off the block,piston chambers and holes where the bolts screw into
Old Aug 26, 2006 | 12:33 PM
frost_0ne's Avatar
Old Aug 26, 2006 | 07:47 PM
frost_0ne's Avatar
anyone???
Old Aug 26, 2006 | 08:14 PM
SVOboy's Avatar
Mess up the firing order?
Old Aug 26, 2006 | 08:34 PM
xisda1's Avatar
is the starter cranking at all or is there nothing
Old Aug 26, 2006 | 08:40 PM
frost_0ne's Avatar
Default Re: NEW HEAD GASKET car wont start!!!!!!!!!!!! (xisda1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Mess up the firing order?</TD></TR></TABLE>
firing order is right...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xisda1 &raquo;</TD></TR><TR><TD CLASS="quote">is the starter cranking at all or is there nothing</TD></TR></TABLE>
starter is cranking as well
Old Aug 27, 2006 | 07:48 AM
saikouEF8's Avatar
check the compression and do a leak down test. to me it sounds like ur head gasket... did u torque everything to spec? did u reuse your old headbolts? is there coolant in your oil? did u "burp" ur coolant system?
Old Sep 14, 2006 | 01:57 PM
Danger's Avatar
Default Re: NEW HEAD GASKET car wont start!!!!!!!!!!!! (saikouEF8)
maybe some bad karma from all the stealing you do ?
CD0419
Honda Civic (2001 - 2005)
Oct 21, 2017 09:23 PM
alexpreludewi
Feb 7, 2016 11:22 AM
MHM2008
Mar 14, 2013 10:26 AM
integra95
Apr 18, 2003 09:14 PM
