rear main seal removel?
Old Aug 25, 2006 | 01:16 PM
90hbvtec's Avatar
Default rear main seal removel? UPDATE!!
guys that took out ur rear main seal..how did you remove that seal...without having to take out the plate? like what tool did you guys use.....also anyone have the part # on this rear main seal..?
update..everthing went on fine i could not take off the passenger side axles so i left them on with no problems..now i started up the car started up fine..i let it idle up for alittle bit...now about to put it into gear, it wont..would not go into gear..what could i possible done wrong this time..PLEASE help..anyone had this issue before...oh yeah i installed new clutch and lighten flywheel....help..
Modified by 90hbvtec at 4:06 PM 8/29/2006
Old Aug 25, 2006 | 01:27 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: rear main seal removel? (90hbvtec)
man I tried taking out my rear main seal last time I changed my clutch, and I couldn't get to budge very easily. I was afraid of scratching the bore, so I just left it in there.
Now on my brother's del Sol when we did the clutch, he needed a new oil pan gasket and rear main, so I just took the whole plate out while the oil pan was off, and it made the job a ton easier.
Old Aug 25, 2006 | 03:02 PM
95 integra's Avatar
Part # 91214-PH1-004
You can use a flat-head to pry it out, though if you already have the tranny off, you might as well put the extra 5 minutes into it and take the plate off so you dont scratch of the crankshaft or anything.
Old Aug 27, 2006 | 11:28 AM
Community Builder
Default Re: rear main seal removel? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Part # 91214-PH1-004
You can use a flat-head to pry it out, though if you already have the tranny off, you might as well put the extra 5 minutes into it and take the plate off so you dont scratch of the crankshaft or anything.</TD></TR></TABLE>
probably best to go ahead and change the oil pan gasket while you're at it, and make sure you don't overtighten the oil pan gasket bolts when you put it back on. They take 9 lb-ft.
Old Aug 27, 2006 | 11:31 AM
miamijdmcoupe524's Avatar
Default Re: rear main seal removel? (PatrickGSR94)
i used a snap on pic to remove and used a small rubber mallet to install no problems to date after almost two months
Old Aug 29, 2006 | 03:04 PM
Integritycaptain90's Avatar
hey bud i could really use a reply on this one. my real main oil seal has been leaking for about 11 months, i was really waiting to purchase everything at once,"clutch,flywhell,alxes, etc. but.... if there is a way to yank it out and replace without having to go through all that it would be da s*#t. Was there a specific reason why your seal wouldnt come out easier. i already have the seal. Plz let me now im paying more for oil than gas.
Old Aug 29, 2006 | 05:49 PM
IN VTEC's Avatar
Default Re: rear main seal removel? (Integritycaptain90)
The rear main seal has a really stiff outer shell. I had to set it up on a pair of 2'x4's and knock it out with a pin punch and hammer by going around the edge and breaking it loose as I went.
To install the new seal, I flipped the cover over on the 2'x4's and used another 2'x4' to knock it in flush with the face of the cover. It was a pretty easy 10 minute job.
Old Aug 29, 2006 | 06:17 PM
B18C Turbo's Avatar
you must make absolutely sure NOT to nick the bore at all. Never use a flat head screwdriver or even a pin pick.
Take the plate out, just do it and remove it by hand, its hard but it will come.
Old Aug 29, 2006 | 08:36 PM
Community Builder
Default Re: (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo &raquo;</TD></TR><TR><TD CLASS="quote">you must make absolutely sure NOT to nick the bore at all. Never use a flat head screwdriver or even a pin pick.
Take the plate out, just do it and remove it by hand, its hard but it will come.</TD></TR></TABLE>
Yep I agree here. Just go ahead and pull the oil pan off to remove that plate. Also replace the oil pan gasket while it's off.
You'll have to support the engine with a jackstand on the very rear pass. side corner of the block, since you're pulling the oil pan off and there will be no tranny on the engine to support the pass. side.
rogue420
14
Jul 18, 2010 05:44 PM
kadidle
Oct 10, 2007 04:26 PM
EF mark
Mar 26, 2006 12:40 PM
overdose
Apr 23, 2003 10:57 AM
CivicTuneR95
Jan 13, 2003 10:17 AM
