EGR block off valve on ebay?? How does it work and how do you put it on?
has anyone heard about this? I just bought the thing and the guy sent it to me and i just recieved a small piece of aluminum, if i am going to recieve something that i paid for my car i might as well use it. Anyways, does anyone know how to put this on or where the egr pipe is?
Here are what the instructions say:
"EGR BLOCK MOD
1. Disconnect battery
2. Locate EGR piping and unbolt it
3. Scribe a piece of paper over the hole left by the piping removed so that the sheet metal will cover the hole.
4. Cut a piece of sheet metal by using the piece of paper to cover the hole/s left by the piping.
5. Drill hole/s through the sheet metal so you can bolt it down over the hole/s
6. Bolt down securely so it doesn't leak
7. Reconnect battery
For off road use only"
That is all that is says. could someone point me to where there is an egr or if there even is one? I spent 10 bucks on this thing and i am not goin to let what i did get, go to waste. By the way if you do try to get this thing, don't, you have the directions here and all you do is get the piece of paper with the directions and like a 6x10 piece of aluminum. Either way anyone know how to apply this mod??
Thanks,
Matt
"EGR BLOCK MOD
Thanks,
Matt
steve_s
12
Apr 27, 2003 02:09 PM
