start/ idle problem? waterlogged? HELP
hey so I was going home from work in one of the worst storms ever (streets were flooded and everything) and I think I got some water in my engine (everywhere)... anyways I got home and parked and everything was good until I tried to start it up again.
At first, it started, but ran at a higher idle and then died. it seemed like everytime I opened the throttle up it would die out.....
What could be the problem?
UPDATE: my ecu is blinking code 5... so I busted my map sensor ( code 5 is usually mechanical right?) how would this have broken because of waterlogging?
also where can I get the sensor/ hose for this???
EDIT:
fixed it just follow the faq
Modified by Poptart at 5:54 PM 8/25/2006
EDIT:
Code 5 - MAP Sensor
Usually means there is something wrong with the hose.
When the MAP voltage is too high (indicating vacuum is lower then normal) the problem is rarely a faulty sensor, but in fact a problem with the engine itself
incorrect cam timming
incorrect iginition timming
restricted exhaust
excessively worn engine or leacking valves
restricted exhaust
Prevail
Feb 26, 2003 05:57 AM
