zc swap
Old Aug 25, 2006 | 11:54 AM
gator88's Avatar
Default zc swap
searched, but to swap a ZC in an 88 crx si, all i need is the longblock right? i can use everything else from my si? that is what i read, but other places/people say there is more. I know its a dumb question, but i just need to know. also, is it true that it is better to get an 88-89 integra ecu, that it helps performance. people with the swap done, tell me what all you did please, and what all you bought. I figured i will do all the basic maint items when i get it.
Old Aug 25, 2006 | 12:02 PM
zccr-xsi's Avatar
u can use every thing from the singlecam.just buy a ZC engine and PM7 ecu.only wiring u got to do is unpin 2 wires form the dizzy clip.which go over to the cps.
Old Aug 25, 2006 | 12:09 PM
zccr-xsi's Avatar
Default Re: zc swap (gator88)
Old Aug 25, 2006 | 12:19 PM
Jun805's Avatar
Default Re: zc swap (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">u can use every thing from the singlecam.just buy a ZC engine and PM7 ecu.only wiring u got to do is unpin 2 wires form the dizzy clip.which go over to the cps.</TD></TR></TABLE>
yup that's wut i did on my crx back when i had it, but i ran a 90 ls ecu
Old Aug 25, 2006 | 12:22 PM
gator88's Avatar
Default Re: zc swap (Jun805)
thank you. Anyone turbo a zc with around 10 lbs boost? i am thinking of going that route next summer. running a good fuel management program, what bhp or whp did you achieve?
Old Aug 25, 2006 | 12:30 PM
zccr-xsi's Avatar
forget that crappie ls ecu.find dohc pm7 computer.88 89 teggie runs it lil rich and your car will smoke a bit.stay with the ecu that is matched for your motor.
or u can chip your 89 si ecu and get pm7 maps put in it.prob. be cheaper way out.then ull have a chipped ecu all ready to be tuned for boost.
Old Aug 25, 2006 | 12:41 PM
gator88's Avatar
Default Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">forget that crappie ls ecu.find dohc pm7 computer.88 89 teggie runs it lil rich and your car will smoke a bit.stay with the ecu that is matched for your motor.
or u can chip your 89 si ecu and get pm7 maps put in it.prob. be cheaper way out.then ull have a chipped ecu all ready to be tuned for boost.</TD></TR></TABLE>
thanks, ill do that then. can rywire do that for me? i cant wire ****, just no experience, and want it done right from the get-go. what would it run me do you think to do the ^^^?
Old Aug 25, 2006 | 12:46 PM
zccr-xsi's Avatar
yea rywire has what u need.
myJDM89EF
Sep 12, 2005 11:05 AM
90b20b4
Jun 27, 2005 02:43 PM
yomomz
Dec 18, 2004 04:48 PM
slowman
Jun 17, 2002 11:55 AM
