LS OIL PAN QUESTION
Quick question, i have an idea i just wanna double check
im reaplacing my LS oil pan an new gasket
i took off the old gasket off my new pan, and there some rubber that has stuck to it, whatdo you recomend to take off. theres not much
and theres a smooth side an a side with grooves on it, the grooves go on the pan and the smooth part goes on the block correct ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 608 Gangsta »</TD></TR><TR><TD CLASS="quote">
and theres a smooth side an a side with grooves on it, the grooves go on the pan and the smooth part goes on the block correct ?</TD></TR></TABLE>
Get a razor blade/exacto knife and clean up the old rubber and install the new seal and bolt it up
trooper0641
14
Oct 11, 2005 07:11 PM
