B18A Not Starting
Old Aug 25, 2006 | 10:48 AM
bboy_mikey's Avatar
Default B18A Not Starting
K so here’s the story. The car died while I was driving it and I pushed it all the way home it was far as hell. The first thing I did was check for sparks and it was not sparking but when I hooked jumper cables to another car the car started right up…I already replaced the distributor cap, New fuses, checked for loose ground (I’m going to double check for loose/ corrosion ground again), new spark plugs, changed my starter that I had in my room, and a new alternator. I know for sure I needed a new alternator because I took my old one to auto zone and got it checked and they said I had a fried alternator and a low battery so I charged the battery and installed the new alternator and the car still doesn’t start. Anyway can any of ya’ll give me some suggestions before I consider taking my car to a mechanic that’ll cost even more money. This is by far the biggest no start problem I have ever encountered.
Old Aug 25, 2006 | 12:29 PM
95 integra's Avatar
Default Re: B18A Not Starting (bboy_mikey)
New battery should fix it right up.
Old Aug 25, 2006 | 03:22 PM
bboy_mikey's Avatar
i had my battery checked at auto zone and the auto meter said its still good and theres no need for a new battery
Old Aug 25, 2006 | 04:25 PM
bboy_mikey's Avatar
alought i have a new distirbutor cap should i geta rotor as well?
Old Aug 25, 2006 | 06:50 PM
tegswin's Avatar
Default Re: (bboy_mikey)
does it just turn over?
if it just sits and turns over without spark, then a common issue is the ignitor
it is inside the distributor so either buy a new ignitor and stick it in, or buy a new distrib.
thats my best guess atm
Old Aug 25, 2006 | 07:05 PM
ErMaK's Avatar
Default Re: (tegswin)
Bad Ignition Coil?
Old Aug 25, 2006 | 08:04 PM
bboy_mikey's Avatar
it could be the ignitor i swapped out the zc kind and still no start does the zc ignitor even works i mean it does fit and everything and i have not tried the ignition coil yet, im also wondering why theres no spark in my car yet the car starts after a jump charge... does anybody have the answer to that? lemme know thanks
Old Aug 28, 2006 | 01:51 PM
bboy_mikey's Avatar
so does anybody know if this will work or not? A crx zc distributor ignitor installed into a b18a1 distrubitor i did install the zc ignitor my self and it fits fine but my car still wont start.
and does anybody know the answer to this. my car would only start if i got jumper cables connected from another car it would start right up and drive just fine until i decide to park the car then it would not start anymore i got it jump charged a few times but after a few times my car would not start anymore after hooking on jumper cables i think i might of fried something im thinkin the alternator/starter is that how i fried my old alternator?
cause a week later i got my alternator checked and it was indeed fried so i got a new alternator and i found out my battery was low so i got that charged.
Old Aug 28, 2006 | 08:49 PM
bboy_mikey's Avatar
nevermind ya'll i got my car running iono what i did tho i swapped my ignitor with a zc i checked for loose wire i replaced my fuse and it started right up
Old Aug 28, 2006 | 09:33 PM
Danziver's Avatar
Ignitors seem to be a common problem with our cars.
d_EG COUPE
Oct 31, 2009 02:48 PM
PremiumPrelude
Feb 24, 2009 07:43 PM
ek4ferrio
Aug 29, 2008 10:26 PM
misterT
Jul 15, 2008 02:13 PM
Ideal
Aug 1, 2005 04:19 PM
