Manual tranny problems... possible causes?
Old Apr 26, 2002 | 05:15 PM
TypeSH's Avatar
Default Manual tranny problems... possible causes?
Ahh... things keep getting worse. What started as a 5th gear only grind, is getting worse. Sometimes, not always, getting into gear is much harder now, noticeably notchier in all gears now =| . I have grinded 2nd once or twice w/ the clutch fully in (I was certain), not sure why it did that.
Also, when the engine is at high rpms, the shift lever shakes pretty badly if i just move it right/left from neutral position. Is it supposed to do that? Could misaligned or bad tranny cables be causing all of my troubles?
Should i actually have the tranny yanked apart?
Or could it be the clutch?
Ahh, gimme some ideas/possibilities people.
Old Apr 26, 2002 | 05:19 PM
Accord94DX's Avatar
Default Re: Manual tranny problems... possible causes? (TypeSH)
syncros.
Old Apr 26, 2002 | 05:32 PM
SOHCArchangel's Avatar
Default Re: Manual tranny problems... possible causes? (Accord94DX)
change the fluid to redline mtl or bg synchroshift, that will cure the grinding
Old Apr 26, 2002 | 07:50 PM
TypeSH's Avatar
Default Re: Manual tranny problems... possible causes? (SOHCArchangel)
oh yea, forgot to mention, the fluid is good.
flukeDC4
Jan 15, 2005 06:41 PM
GWInquisitor14
Oct 15, 2004 10:06 AM
love2xlr8integra
Jun 26, 2004 11:22 PM
JDM-Vic
Apr 6, 2004 01:48 PM
stilzx61
Feb 14, 2004 01:28 AM
