so i got his code 3, 5 what's going on??????????????????????
Old Aug 25, 2006 | 09:26 AM
philosofy1's Avatar
Default so i got his code 3, 5 what's going on??????????????????????
ok, yesterday my car started acting up. thought it was the o2 sensor. well i guess it's not. so i decided to read the ecu for codes. i ended up getting a 3, which is a map sensor code.
i replaced the map and now it's giving me a 5, which is also a map code. so i'm thinking someting is triggering the map to shoot this code. what can trigger a map code?
it's a 93 dx, with a jdm b16a!
Old Aug 25, 2006 | 09:34 AM
philosofy1's Avatar
Default Re: so i got his code 3, 5 what's going on?????????????????????? (philosofy1)
come on honda guru's. i know you're out there.
Old Aug 25, 2006 | 09:39 AM
philosofy1's Avatar
bump
Old Aug 25, 2006 | 09:53 AM
philosofy1's Avatar
i need some help guys, i know there is someone on here who knows!
Old Aug 25, 2006 | 10:12 AM
EGwhat!!!'s Avatar
disconnect the MAP sensor connector, turn ignition key ON (engine not running) and check for voltage between the power and ground wires in the harness side of the connector. there should be approximately 5 volts. if not, check the wires for breaks and poor connections repair as needed. try that only thing i could think of.
Old Aug 25, 2006 | 11:50 AM
philosofy1's Avatar
Default Re: so i got his code 3, 5 what's going on?????????????????????? (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the MAP sensor connector, turn ignition key ON (engine not running) and check for voltage between the power and ground wires in the harness side of the connector. there should be approximately 5 volts. if not, check the wires for breaks and poor connections repair as needed. try that only thing i could think of.</TD></TR></TABLE>
thanks, i didn't think about that. this crap has be stressed out! if anyone else has any advice, please feel free.
Old Aug 25, 2006 | 12:10 PM
philosofy1's Avatar
i need a valve adjustment, can this trigger a code 3, 5 (map sensor).
Old Aug 26, 2006 | 06:55 AM
philosofy1's Avatar
hello?
Old Aug 26, 2006 | 07:23 AM
Dilly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">hello?</TD></TR></TABLE>
haha. sorry, i dont have any idea. bump for a nice guy.
Old Aug 26, 2006 | 07:30 AM
hondaboy4life's Avatar
Default Re: so i got his code 3, 5 what's going on?????????????????????? (dillywong)
1st check to see if u get power and ground, then we'll move onto other things. i dunno if valve adjustment matters, but i dont think so.
Old Aug 26, 2006 | 07:35 AM
philosofy1's Avatar
Default Re: so i got his code 3, 5 what's going on?????????????????????? (hondaboy4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboy4life &raquo;</TD></TR><TR><TD CLASS="quote">1st check to see if u get power and ground, then we'll move onto other things. i dunno if valve adjustment matters, but i dont think so.</TD></TR></TABLE>
thanks guys!
FSUseminoleEM1
Feb 19, 2010 08:34 AM
speedooo
11
Jul 24, 2008 09:27 AM
eggie75
Apr 7, 2008 01:40 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
Frosty_spl
Feb 12, 2002 02:06 PM
