Ls vtec: crank girdle?
Old Aug 25, 2006 | 07:47 AM
chu77's Avatar
Default Ls vtec: crank girdle?
What is a crank girdle? will it help the block at higher rpm?
I've heard to install the crank girdle, then a GSR/ITR oil pick up, windage tray and oil pan would be swaped over to the ls block? Is it a driect bolt on? or you'll have to machine it?
Old Aug 25, 2006 | 12:04 PM
unknown0001's Avatar
Default Re: Ls vtec: crank girdle? (chu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chu77 &raquo;</TD></TR><TR><TD CLASS="quote">What is a crank girdle? will it help the block at higher rpm?
I've heard to install the crank girdle, then a GSR/ITR oil pick up, windage tray and oil pan would be swaped over to the ls block? Is it a driect bolt on? or you'll have to machine it?</TD></TR></TABLE>
You need to modify them to fit
https://honda-tech.com/zerothread?id=1014696
https://honda-tech.com/zerothread?id=1029472
Teamdiesel
Apr 14, 2007 05:31 PM
bigsubs
Jul 14, 2006 12:19 AM
TheThiefTheKnife'NTheGun
Jan 19, 2005 10:20 AM
jmonee112
Jul 7, 2004 09:43 AM
