F20B valves...
Old Aug 25, 2006 | 06:44 AM
SiR-T's Avatar
Default F20B valves...
ok, obviously the H22 valves are easy to find, but I have a F20B and my valves might be bent, is their any aftermarket support for the F20B valves? anyone makes um? can the H22 valves b used?
Old Aug 25, 2006 | 09:04 AM
ExplicitSpeed360's Avatar
Banned.
Default Re: F20B valves... (SiR-T)
I believe the H22A valves may work with the f20b. The f20b valves are 1mm smaller. So in theory if you used the h22a valves be 1mm oversized from the std f20b. I am not sure if everything else is the same either...From what I heard the valves are the weak link in the f20b engine? Correct me if I am wrong...
Old Aug 25, 2006 | 10:20 AM
SiR-T's Avatar
Default Re: F20B valves... (ExplicitSpeed360)
thanks for the info, honestly im not sure if they are the weak link cuz my engine has a bit of miles on it and still going strong, my timing belt burst the other day and i tried starting the car a couple times afterwards. is it a bad thing to keep trying to start it?
Old Aug 25, 2006 | 11:20 AM
bluedlude's Avatar
if your engine is your heart then the timing belt is a main artery. do not try to start it anymore. you will just CONTINUE to bend valves.
tha Big EZ
Aug 11, 2003 09:50 AM
