Help with auto trans shifter!!!
Old Aug 25, 2006 | 01:45 AM
paxamus's Avatar
Default Help with auto trans shifter!!!
Hey everyone,
We are moving in 4 days and guess what, now my wifes Accord will not shift sometimes into R or D. I can't figure it out. When you push the button on the shift lever, sometimes it is so damn hard to press you can't shift it nad then other times it is fine. I took the shiftl lever apart and that helps sometimes. I am confused, anyone got any ideas???? (I checked the ATF and all is good)
Thanks
Old Aug 25, 2006 | 12:08 PM
silversir's Avatar
Default Re: Help with auto trans shifter!!! (paxamus)
What year is it? I believe that the 98-02 had a recall on that problem, but I'm not completely sure.
Old Aug 25, 2006 | 03:49 PM
Honda-Master's Avatar
if you mean it won't shift from park,, when that happens chk to see if the brake lites are working ,, you might have a bad brake switch
Old Aug 25, 2006 | 04:46 PM
02 accord's Avatar
Don't force it. Use the release next to the shifter if it gets stuck in park.
Old Aug 26, 2006 | 08:40 AM
paxamus's Avatar
Default Re: Help with auto trans shifter!!! (02 accord)
I have taken the shift **** off and if you manually push down on the white plastic sleeve then push down on the inner metal rod it will work, but you also have to fool with it sometimes. I guess that I will leave as is until we get to BAMA and then let someone look at it. Thanks for the sugestions.
Old Aug 26, 2006 | 08:47 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paxamus &raquo;</TD></TR><TR><TD CLASS="quote">I have taken the shift **** off and if you manually push down on the white plastic sleeve then push down on the inner metal rod it will work, but you also have to fool with it sometimes. I guess that I will leave as is until we get to BAMA and then let someone look at it. Thanks for the sugestions.</TD></TR></TABLE>
If you're going to drive it make sure the brake lights are working. Sounds like the brake switch is getting sticky.
Old Aug 26, 2006 | 09:08 AM
BLKFLSH's Avatar
Default Re: Help with auto trans shifter!!! (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
If you're going to drive it make sure the brake lights are working. Sounds like the brake switch is getting sticky.</TD></TR></TABLE>
Definitely, make sure the brake lights work. And, do you hear a click inside the console when you press the brakes?
susboy102
Jul 16, 2014 08:31 AM
MJMAccord
Aug 22, 2010 03:23 PM
ChevelleSSLS6
Apr 7, 2009 09:16 AM
GimpyVtec
Sep 14, 2007 09:31 PM
yellowdcn
Feb 28, 2005 01:06 PM
