Two Quick Questions
first, are the top hats in the front of a 2000 civic the same on both sides? like i can use the left top hat on the right side and vice versia?
second, how do you assemble the top hat? there are two rubber bushings one on top and one of bottom and one of those has a metal tube in the middle.
so which one goes on top/bottom and which one is the tube supposed to go through?
first, yes theyre the same.
second, the top and bottom bushings are the same too. the sleeve just ends up sticking to one or the other. its a separate piece. you put the sleeve in the middle and the two bushings sandwich each other like a hamburger with two sesame seed buns.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">first, yes theyre the same.
second, the top and bottom bushings are the same too. the sleeve just ends up sticking to one or the other. its a separate piece. you put the sleeve in the middle and the two bushings sandwich each other like a hamburger with two sesame seed buns. </TD></TR></TABLE>
ahh ok thanks.
but the two bushings are diff shapes or that doesnt matter at all anyways?
ahh ok thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">no. one is just more worn than the other.</TD></TR></TABLE>
you sure? there are two that are totally diff than the other two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">take a pic....</TD></TR></TABLE>
i dont have a camera but i'll try to see if my phone can show everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">they have part numbers embossed on them. youll see theyre the same.</TD></TR></TABLE>
the #'s are the same...haha. but here's a pic
the others are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">so to answer your question:
yes, i am sure.
haha ok thats werid that they only 2 look the same and the other two look the same.
so it wouldnt matter which went where and where the tube went?
yes, i am sure.
</TD></TR></TABLE>haha ok thats werid that they only 2 look the same and the other two look the same.
NathanMorris
Suspension & Brakes
Feb 13, 2008 08:22 AM
WhiteOnRice
Oct 25, 2006 06:58 PM
kaj
Jan 30, 2005 10:23 AM
